Hi!
PC version 6,49,7
After turning off the power, it gives an error when the system is rebooted.
failed to stop ipsec: std failure: timeout (13)
Missing Routh Records (IP>Routes)
Restoring from a backup does not help.
Everything is restored except routes.
If you make an OS reset and upload a backup from a text file, then everything works. But until the moment of crediting the power supply
how to eliminate?
same problem on ROS 7.6 X86.
updated to version 7.13 (x86) - same problem
how to solve a problem?
Still problem on 7.16.1 and CCR-2116-12G-4S+
