I sent 3 emails trying to get any type of response to get my router replaced or fixed - nothing! What does a user need to do to get support@microtik.com to respond? I was following the rma / support instructions, but I received no reply.
I purchased this router and configured it and it was working great…for less than 3 months. Then it D-Conned both systems and ceased working altogether. I reset it to defaults and no address (DHCP) came down. I set static IPs and could not reach the router. I hooked up the micro-USB connection - windows reacted badly and reported that the connected hardware was in error.
I know about routers pretty well and am not afraid to troubleshoot hardware / software. I am not sure the response profile for the USB connection, but I suspect that it is not normal.
how about it Microtik? Loved the router when it was operational, and I am not really happy with my old Linksys one. I bought it internationally (shipped from ubntshop on may 5-7 2013). Would this not qualify for some sort of support as it has been non-functional for over 3 weeks?
Also you are writing to a non-existant email address. Just like you can see in the logo in this forum (and also address bar), correct email is support@mikrotik.com (all “k” letters)
You guys are SOOOO correct and I apologize profusely. I have been sending to support@microtik.com ( no bounce tho! grrr ). I have sent a post to Ubntshop to see what they will do. Thanks much for the heads up.
Mikrotik have been very good with replacements when something has died and three months is well within the year.
The only thing I will note if that you will need to check with your supplier if they do forward replacements. Otherwise you can wait a while. The supplier will usually do some testing and see if they can do a local repair, if not then they send it back to Mikrotik for repair.
Some suppliers will send you back one and then take the repaired one back into to stock but that is a discussion for you and your supplier.
