is there limitation to masquerade on VLAN interface?
VLAN 100 is facing towards LAN and VLAN 1000 on WAN.
LAN has ip 10.100.21.220/24 and its trying to
A client machine is trying to reach to internet but failing.
add action=masquerade chain=srcnat ipsec-policy=out,none out-interface=vlan1000 src-address-list=InternalSubnet
Full config snipset
add admin-mac=F4:1E:57:51:6A:51 auto-mac=no comment=defconf name=bridge vlan-filtering=yes
set [ find default-name=sfp28-1 ] comment=WAN
set [ find default-name=sfp28-2 ] comment=WAN
/interface vlan
add comment=Mgmt interface=bridge name=vlan100 vlan-id=100
add comment=WAN interface=bridge name=vlan1000 vlan-id=1000
add name=WAN
add name=dhcp_pool0 ranges=10.100.21.220-10.100.21.253
add address-pool=dhcp_pool0 interface=vlan100 lease-time=7h30m name=dhcp1
/port
set 0 name=serial0
add bridge=bridge comment=defconf disabled=yes interface=ether1
add bridge=bridge comment=defconf interface=qsfp28-1-1
add bridge=bridge comment=defconf interface=qsfp28-1-2
add bridge=bridge comment=defconf interface=qsfp28-1-3
add bridge=bridge comment=defconf interface=qsfp28-1-4
add bridge=bridge comment=defconf interface=qsfp28-2-1
add bridge=bridge comment=defconf interface=qsfp28-2-2
add bridge=bridge comment=defconf interface=qsfp28-2-3 pvid=100
add bridge=bridge comment=defconf interface=qsfp28-2-4 pvid=100
add bridge=bridge comment=defconf interface=sfp28-1 pvid=1000
add bridge=bridge comment=defconf interface=sfp28-2 pvid=1000
add bridge=bridge comment=defconf interface=sfp28-3
add bridge=bridge comment=defconf interface=sfp28-4 pvid=100
add bridge=bridge comment=test interface=sfp28-5 pvid=100
add bridge=bridge comment=test interface=sfp28-6 pvid=100
add bridge=bridge comment=test interface=sfp28-7 pvid=100
add bridge=bridge comment=test interface=sfp28-8 pvid=100
/interface ethernet switch l3hw-settings
set autorestart=yes
/interface bridge vlan
add bridge=bridge untagged=sfp28-1,sfp28-2 vlan-ids=1000
set 0 l3-hw-offloading=yes qos-hw-offloading=yes
/interface ovpn-server server
add mac-address=FE:7E:F7:37:45:60 name=ovpn-server1
add address=192.168.2.102/24 comment=defconf interface=ether1 network=192.168.2.0
add address=90.152.xx.xx/29 interface=vlan1000 network=90.152.xx.xx
/ip dhcp-client
add disabled=yes interface=ether1
add address=10.100.21.0/24 dhcp-option-set=test dns-server=10.255.11.1,8.8.4.4,8.8.8.8 gateway=10.100.21.254 ntp-server=10.255.11.1
/ip dhcp-server option sets
add name=test options=*2,AIWS
set servers=8.8.8.8
/ip firewall address-list
add address=10.100.21.0/24 list=InternalSubnet
add action=accept chain=forward comment="Accept all chains"
add action=add-src-to-address-list address-list=Syn_Flooder address-list-timeout=30m chain=input comment="Add Syn Flood IP to the list" connection-limit=30,32 protocol=tcp tcp-flags=syn
add action=drop chain=input comment="Drop to syn flood list" src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner address-list-timeout=1w chain=input comment="Port Scanner Detect" protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment="Drop to port scan list" src-address-list=Port_Scanner
add action=jump chain=input comment="Jump for icmp input flow" jump-target=ICMP protocol=icmp
add action=drop chain=input comment="Block all access to the winbox - except to support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUPPORT ADDRESS LIST" dst-port=8291 protocol=tcp src-address-list=!support
add action=jump chain=forward comment="Jump for icmp forward flow" jump-target=ICMP protocol=icmp
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=bogons
add action=add-src-to-address-list address-list=spammers address-list-timeout=3h chain=forward comment="Add Spammers to the list for 3 hours" connection-limit=30,32 dst-port=25,587 limit=30/1m,0 protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 protocol=tcp src-address-list=spammers
add action=accept chain=input comment="Accept DNS - UDP" port=53 protocol=udp
add action=accept chain=input comment="Accept DNS - TCP" port=53 protocol=tcp
add action=accept chain=input comment="Accept to established connections" connection-state=established
add action=accept chain=input comment="Accept to related connections" connection-state=established,related
add action=accept chain=input comment="Full access to SUPPORT address list" src-address-list=support
add action=accept chain=ICMP comment="Echo request - Avoiding Ping Flood, adjust the limit as needed" icmp-options=8:0 limit=2,5 protocol=icmp
add action=accept chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=icmp
add action=accept chain=ICMP comment="Time Exceeded" icmp-options=11:0 protocol=icmp
add action=accept chain=ICMP comment="Destination unreachable" icmp-options=3:0-1 protocol=icmp
add action=accept chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP comment="Drop to the other ICMPs" protocol=icmp
add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP protocol=icmp
add action=drop chain=input comment="Drop anything else! # DO NOT ENABLE THIS RULE BEFORE YOU MAKE SURE ABOUT ALL ACCEPT RULES YOU NEED" in-interface=vlan1000
/ip ipsec policy
add dst-address=10.255.11.0/24 peer=fortigate proposal=fortigate-enm src-address=10.100.21.0/24 tunnel=yes
add dst-address=10.255.11.0/24 peer=fortigate proposal=fortigate-enm src-address=10.105.21.0/24 tunnel=yes
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=90.152.35.137 routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/London
/system identity
set name=new
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes
/system ntp client servers
add address=0.pool.ntp.org
add address=1.pool.ntp.org
add address=2.pool.ntp.org
add address=3.pool.ntp.or
add address=3.pool.ntp.org
/system routerboard settings
set enter-setup-on=delete-key
/tool sniffer
set file-name=test filter-interface=sfp28-4
Thanks.
