Hello
I am setting up a mikrotik RB751 into a hotspot gateway. I follow all the steps given into setting a hotspot but cannot get it done successfully. Here is the information I get once I print the configuration inside my router.
[admin@MikroTik] /ip hotspot> print
Flags: X - disabled, I - invalid, S - HTTPS
NAME INTERFACE ADDRESS-POOL PROFILE IDLE-TIMEOUT
0 I hotspot1 ether2-master… hs-pool-2 hsprof1 5m
Can anyone help to successfully setup the hotspot such that I can reach the login page which will require a username and a password.
Regards
Vectorsd
