I have been trying to configure my hapAC² to run a pppoe-server on a vlan for several hours. I am failiing at moving the working pppoe-server configuration into the vlan specifically. I want to require my client notebook to use vlan 7 before pppoeing into the network. The use case is academic.
# RouterOS 7.11
# software id = **ELIDED**
# model = RBD52G-5HacD2HnD
add ageing-time=5m arp=proxy-arp arp-timeout=auto auto-mac=yes dhcp-snooping=no disabled=no ether-type=0x8100 fast-forward=no frame-types=admit-all \
igmp-snooping=no ingress-filtering=yes mtu=auto name=pppoe-bridge protocol-mode=none pvid=7 vlan-filtering=yes
add auto-isolate=no bpdu-guard=no bridge=pppoe-bridge broadcast-flood=yes disabled=no edge=auto fast-leave=no frame-types=admit-only-vlan-tagged \
horizon=none hw=yes ingress-filtering=yes interface=ether4 internal-path-cost=10 learn=auto multicast-router=temporary-query path-cost=10 \
point-to-point=auto priority=0x80 pvid=7 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes \
unknown-unicast-flood=yes
# egress rule
/interface bridge vlan
add bridge=pppoe-bridge disabled=no tagged=ether4,pppoe-bridge untagged="" vlan-ids=7
and a pppoe-server on that bridge:
/interface pppoe-server server
add default-profile=profile1 disabled=no interface=pppoe-bridge max-mtu=1492 one-session-per-host=yes service-name=ppoe-service
I have a linux connected to ether4 with a wireshark on the pyhsical eth2 (watching both tagged and untagged traffic) while trying to pppoe-discover on vlan 7 (eth2.7).
What I would expect is that vlan 7 gets stripped from the request then answered by the pppoe-server. The untagged reply should then be tagget before being sent out through ether4 due to the egress rule.
What I see on wireshark is a request on VLAN 7 but an untagged reply.
I did try to create a VLAN7 interface on the bridge and run the pppoe-server on that instead with no success. All switch port settings are on their default (vlan-mode disabled, vlan-header leave-as-is). I followed the very detailed setup explanation at https://www.youtube.com/watch?v=YMwOrc0LDP8.
What am I missing?
