Failover CCR1036-12G-4S
Hi All,
I have 2 ( two ) buildings which i connect them via fiber.
LAN on both sites are on the same subnet ( for example : 192.168.0.0/24 )
To prevent downtime should there be any fibercut, I added a direct point to point wireless ( it can provide 400+ Mbps in real world for 1 km distance )
The scenario is that when the fiber connection drops ( fibercut ) the connectivity between the two buildings will be moved to this wireless backhaul automatically.
And when the issue ( fibercut ) is resolved, the connectivity will be moved back automatically to the fiber line.
So I bought myself 2 ( two ) CCR1036-12G-4S and put them on both sites as on the figure below.
I tried to use bridging but it seems only works when I unplug the fiber interface on the CCR router but not when fibercut occurs.
Any ideas will be very much appreciated.
Thank you!
