Failover error
You’ll have to ask a question with some additional information. The above just shows that the gateway of 192.168.1.1 is reachable.
thanks for the reply the question is that I can not reach recursive3 and 4
Right, you have a check gateway setup I’d assume. Can you ping 4.2.2.3 from 192.168.1.1?
if I can ping the recursive 4.2.2.3 or 4.2.2.4 from 192.168.1.1 new terminal mikrotik
