Failover on pppoe Client DSL
I have 2 DSL connections both are set on pppoe Client I am using nth load balancing I want to configure failover also how it possible on pppoe-out1 and pppoe-out2
no one ?
hi there
try this
/ ip firewall mangle
add chain=input in-interface=PPPOE1 action=mark-connection new-connection-mark=LINE1
add chain=input in-interface=PPPOE2 action=mark-connection new-connection-mark=LINE2
add chain=output connection-mark=LINE1 action=mark-routing new-routing-mark=to_LINE1
add chain=output connection-mark=LINE2 action=mark-routing new-routing-mark=to_LINE2
add chain=prerouting dst-address-type=!local per-connection-classifier=both-addresses:2/0
action=mark-connection new-connection-mark=LINE1 passthrough=yes
add chain=prerouting dst-address-type=!local per-connection-classifier=both-addresses:2/1
action=mark-connection new-connection-mark=LINE2 passthrough=yes
add chain=prerouting connection-mark=LINE1 action=mark-routing new-routing-mark=to_LINE1
add chain=prerouting connection-mark=LINE2 action=mark-routing new-routing-mark=to_LINE2
/ ip route
add dst-address=0.0.0.0/0 gateway=LINE1 routing-mark=to_LINE1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=LINE2 routing-mark=to_LINE2 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=LINE1 distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=LINE2 distance=2 check-gateway=ping
/ ip firewall nat
add chain=srcnat out-interface=LINE1 action=masquerade
add chain=srcnat out-interface=LINE2 action=masquerade
and post comment
rini
my configurations
add action=masquerade chain=srcnat comment="" connection-mark=conn1 disabled=no \
    out-interface=pppoe-out1
add action=masquerade chain=srcnat comment="" connection-mark=conn2 disabled=no \
    out-interface=Uplink2
add action=masquerade chain=srcnat comment="" connection-mark=conn3 disabled=no \
    out-interface=Uplink1
    out-interface=pppoe-out2
add action=masquerade chain=srcnat comment="" disabled=no
/ip firewall mangle
add action=mark-connection chain=prerouting comment="" connection-state=new disabled=no \
    in-interface=Local new-connection-mark=conn1 nth=2,1 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=conn1 disabled=no \
    in-interface=Local new-routing-mark=conn1 passthrough=no
    in-interface=Local new-connection-mark=conn2 nth=1,1 passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=conn2 disabled=no \
    in-interface=Local new-routing-mark=conn2 passthrough=no
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out2 \
    routing-mark=conn2
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=pppoe-out1 \
    routing-mark=conn1
but my problem is when one dsl is down both are not working
u have create to many rules
if u want to make it simple
just make :
/ip firewall mangle
add chain=prerouting protocol=tcp destination-port=1863 action=mark-routing new-mark-routing=TEST
add chain=srcnat action=masquerade
add chain=dstnat action=accept
add dst-address=0.0.0.0/0 gateway=LINE1 routing-mark=TEST distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=LINE2 routing-mark=TEST distance=1 check-gateway=ping
add dst-address=0.0.0.0/0 gateway=LINE1,LINE2 distance=1 check-gateway=ping
if you have different bandwidth for the lines example from LINE1=2Mb and LINE2=4Mb
add dst-address=0.0.0.0/0 gatewaty=LINE1,LINE2,LINE2 distance=1 check-gateway=ping
you have to create raport (in this case 1:2) of gateway and separate them by “,” .
try this and post comment
thanks for reply rini
i am reading you other post (Load balancing with PCC ADSL3)
i have also 2 adsl lines with same bandwith both way connecting pppoe client
pppoe client 1
pppoe client 2
Local Lan
can u plz post your working PCC configuration
here it is
http://forum.mikrotik.com/t/load-balancing-withh-pcc-3-adsl-lines-error/42638/1
