Failover on RB433
Dear all,
i’ve problem
ISP1 ----- Mikrotik (eth1)
ISP2 ----- LAN (eth2)
Laptop’s ------ WLAN
eth1 as default route
eth2 as second route
i can connect all laptops over WLAN but can’t go to internet
can somebody help me thanks
here is my config setting:
test-speedy.rsc (16.6 KB)
Does your pc get ip from the Wlan interface via DHCP? or it’s a static IP? I did’t see any network entry on the /ip dhcp-server network.
could you attach the print out of following code
/ip dhcp-server network print
or check on you pc the output of
route print
hi jackman,
unfortunately, i reset all those configuration, now i use other setting which i switch the ports (eth1) now as LAN and eth2 connected to Speedy. and now it works. Thats strange huh ?
