Failover Scanrio
Can anybody help me in this regards
i have 2 different ISPs, WAN ip addressess and one LAN
i want to configure router board as failover (not load balancer)
what will be the configuration,
please suggest me step by step
i will be very thanful to you.
Regards,
Rashid
In IP→Routes (and IPv6→Routes) you define two routes to 0.0.0.0/0 via the given gateways.
Give the fallback-route a greater value for ›distance‹ than your primary route has and you’re done.
I’m using the advice from this site http://aacable.wordpress.com/tag/mikrotik-fail-over/
Tested this morning as a matter of fact. Worked for me.
We have a wireless 5m feed for a resort and a backup 1.5 m feed.
If the wireless goes down it auto switches to the DSL feed then switches back after the wireless route come back up.
Rick
