Failover trouble
Hi
I'm using this script for failover however when it fails it keeps the route for the existing connection
and since i'm running voip i need to reboot for new routes
I tried some mangle rules but im back to square 1 for now
------------------- header -------------------
Script by Tomas Kirnak, version 1.0.7
If you use this script, or edit and
re-use it, please keep the header intact.
For more information and details about
this script please visit the wiki page at
RouterOS - RouterOS - MikroTik Documentation
------------- start editing here -------------
Edit the variables below to suit your needs
Please fill the WAN interface names
:local InterfaceISP1 WAN1
:local InterfaceISP2 WAN2
Please fill the gateway IPs (or interface names in case of PPP)
:local GatewayISP1 WAN1
:local GatewayISP2 WAN2
Please fill the ping check host - currently: resolver1.opendns.com
:local PingTarget 8.8.8.8
Please fill how many ping failures are allowed before fail-over happends
:local FailTreshold 3
Define the distance increase of a route when it fails
:local DistanceIncrease 2
Editing the script after this point may break it
-------------- stop editing here --------------
Declare the global variables
:global PingFailCountISP1
:global PingFailCountISP2
This inicializes the PingFailCount variables, in case this is the 1st time the script has ran
:if ([:typeof $PingFailCountISP1] = "nothing") do={:set PingFailCountISP1 0}
:if ([:typeof $PingFailCountISP2] = "nothing") do={:set PingFailCountISP2 0}
This variable will be used to keep results of individual ping attempts
:local PingResult
