Hi everyone,
I’d like to set a failover/load balance on my Mikrotik hap ac2.
It should be between ethernet port 5 and WLAN1, so that if WAN on ethernet port 5 goes down the wireless connection setting on Wlan1 (connection from my smartphone device in tethering)
automatically start or keeps working without me noticicing.
I am a bit at a loss as to how to set it properly though.
I managed (I hope) to set up the connection on WLAN1 and it works:
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
add comment=defconf name=WAN
add comment=defconf name=LAN
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name="WAN WiFi VOD" \
supplicant-identity="" wpa2-pre-shared-key=abcddefghilmno123
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n country="united states3" disabled=no frequency=2422 installation=indoor \
keepalive-frames=disabled multicast-buffering=disabled security-profile="WAN01" ssid=vodcon station-roaming=\
disabled wds-default-bridge=bridge wds-mode=dynamic wmm-support=enabled
wmm-support=enabled wps-mode=disabled
add bridge=bridge comment=defconf interface=wlan2
add bridge=bridge interface=wlan3
add bridge=bridge interface=ether1
add bridge=bridge interface=ether3
add comment=defconf interface=wlan1 list=WAN
I am not sure now about how to set the second wan on port ethernet 5, then set a failover/load-balance with the two of them.
Could you help me figured it out please?
