Failover
Hello I have a very instable powerline connection in my bedroom and now I tough i could just use two powerline adapter as for failover reason.
But how could I configure that? I can’t use Bound or could I? Bound over two develo powerline adapters? Really not sure here. The problem is eth1 never goes down just the connection is so terrible that I need to reboot the powerline. Any Idea here?
Anyway that’s the config on my CAP device.
add fast-forward=no name=br-lan
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
/interface mesh
add name=Mesh
/interface lte apn
add authentication-types=wpa2-psk mode=dynamic-keys name=blabla supplicant-identity=""
add authentication-types=wpa2-psk mode=dynamic-keys name=blabla2 supplicant-identity=""
/interface wireless
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-n/ac channel-width=20/40/80mhz-XXXX country=no_country_set disabled=no frequency=auto frequency-mode=manual-txpower installation=indoor mode=ap-bridge name=wlan5 radio-name=blabla5000 security-profile=blabla skip-dfs-channels=all ssid=WLANPrivat station-roaming=enabled wps-mode=disabled
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-g/n channel-width=20/40mhz-XX country=no_country_set disabled=no frequency=auto frequency-mode=manual-txpower installation=indoor mode=ap-bridge name=wlan24 radio-name=blabla2400 security-profile=blabla ssid=WLANPrivat station-roaming=enabled wps-mode=disabled
add disabled=no hide-ssid=yes keepalive-frames=disabled mac-address=76:4D:28:2E:A0:3D master-interface=wlan24 multicast-buffering=disabled name=wlan24_2 security-profile=blabla2 ssid=WLANIOT wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=br-lan ingress-filtering=no interface=ether1
add bridge=br-lan interface=wlan24
add bridge=br-lan interface=wlan5
add bridge=br-lan interface=wlan24_2
add bridge=br-lan interface=ether2
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
/interface wireless cap
set bridge=br-lan certificate=request discovery-interfaces=br-lan interfaces=wlan24,wlan5
/ip dhcp-client
add interface=br-lan
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Zurich
/system identity
set name=ac-og
/system leds settings
set all-leds-off=after-1min
/system ntp client
set enabled=yes
If your current powerline is already instable, adding a second one to the same electrical wires, will only make things worse.
Do you really have no option to pull a normal ethernet cable ? Not even via outside ?
I also used powerline from living room (where modem is) towards my home office. I got around 150mb throughput, I think.
Until I got solar panels installed … the harmonics practically KILLED the powerline throughput (ok, exagerating here but you get the idea :laughing: )
So I pulled a normal CAT6 via office through the floor into the garage, via ceiling of garage into basement, back up to living room.
Internal network is humming at close to 1Gbps now.
I have about 6 Powerline. The problem is only in the 3floor and the second on the 3floor dosn’t have the problem at the same time
