I’m trying to add a DHCP server option by concatenating two string variables into one single string.
:global controlIP "11.11.111.11";
:global hexChar ""; #STR storing hex character
:global option43hex ""; #STR storing entire Option43 value
:set $hexChar "c"
# BELL char used. "s" character is needed in the string.
:set $option43hex ("0x060$hexChar\as'$controlIP'")
/ip dhcp-server option
add code=43 name=Option43 value=$option43hex
Once I do the command to create the option I’m getting this error:
failure: Hex string must have even count of elements!
:put is showing the right string I’m expecting once everything is concatenated:
0x060cs'11.11.111.11'
I’m able to enter that value manually, however when I use my code to add the value the error is happening. What’s causing the error, and what can I do to get around it?
*Edit: Fixed a typo.
