failure: master-port has master-port itself
I am trying to learn how to script a CRS125-24G-1S with the router OS ver 6.33.3. My biggest challenge has come with trying to do this.
/interface ethernet> set [ find default-name=ether22 ] master-port=ether5
/interface ethernet> set [ find default-name=ether21 ] master-port=ether3
each tie this is run I get back the following error
I am currently accessing the router via ether port 1 and the device is in a default configuration.
I have tried
/interface ethernet> set ether4-slave-local,ether6-slave-local,ether8-slave-local master-port=ether2-slave
same results
I am sure a more experienced person will tell me its a simple mistake but I am not seeing it.
It’s saying that ether5 and ether3 are already slaves to another master port (and ether2-slave on your last example). They can’t be nested.
Unset the master-port for ether3 and ether5 first.
So by default are all the ports bonded to ether1?
A CRS without wireless defaults to all ports in one switch group.
Not bonded. Bonding is a different thing, done from the switch menu.
