"failure: not an mstp bridge": Error following MSTP Documentation Example
I’m trying to follow the example in the MSTP documentation: Spanning Tree Protocol - RouterOS - MikroTik Documentation
When I reach the following step:
interface bridge port mst-override add identifier=2 interface=ether1 internal-path-cost=5
I try to run it, but I get the error:
`failure: not an mstp bridge`
I’m following the documentation which sets at the start the bridge protocol as RSTP with vlan-filtering disable to avoid losing remote access, and **not** MSTP. To set the layer2 anti-loop protocol as MSTP, we need to activate vlan-filtering right at the start, or so it seems… Is there a mistake in the documentation?
Wrong section, SwOS do not have "termial"...
Moved.
