failure to update a 3.29 to 4.9 on RB750
Good Teachers:
Well I have a RB750 was with the 3.29 version I wanted to upgrade to version 4.9 via winbox, but after the restart and RB leds do not light despite being offline, I can not access the direct connect to mikrotik.lo computer and says it is connected … but I can not access, try to reset it but nothing … reset not Help … Help please ..
Gerryne
follow the manual and reinstall it with Netinstall if you can’t connect with MAC or IP and reset is not helping.
Thanks for the reply …
Download the netinstall you run it, and nothing … RB750 did not find the manual says to reset the RB to run the PXE boot mode but nothing … it seems that no probe and pressing the reset button shorting reset and also below the leg as shown in the manual .. any other way to reset … or am I doing wrong with the netinstall … please help
Gerrynet
