Here is my setup. I have a Netgear cable modem connected to ethernet port 1 of my MikroTik hAP ac2 router. That them goes from ethernet port 2 to a netgear unmanaged switch. Then from the switch it branches off to my my AP, my Tv, and my home server. Here is my Hap 2ac config. It’s basically just the default config.
# feb/28/2023 14:26:05 by RouterOS 6.49.7
# software id = TPJJ-GKHK
# model = RBD52G-5HacD2HnD
# serial number = HD20xxxxx
add admin-mac=18:FD:74:8F:0F:EF auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce \
country="united states" disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=NachoWifiSucker \
wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX disabled=no distance=indoors frequency=auto \
installation=indoor mode=ap-bridge ssid=NachoWifiSucker5 \
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys \
supplicant-identity=MikroTik wpa2-pre-shared-key=<PASSWORD>
/ip hotspot profile
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wlan2
192.168.88.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1
/ip dhcp-server lease
add address=192.168.88.100 client-id=\
ff:d4:f5:37:c5:0:1:0:1:2b:26:27:0:fc:4d:d4:f5:37:c5 mac-address=\
FC:4D:D4:F5:37:C5 server=defconf
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/system clock
set time-zone-name=America/New_York
/tool mac-server
/tool mac-server mac-winbox
My server is running various services like proxmox, nextcloud, photoprism, and Nginx reverse proxy. I would like to be able to access nextcloud and photoprism from the internet. I have my own google domain that is pointing to my public ip address. I can ping my domain and its resolving to my public ip address. Now I need help forwarding traffic to the Nginx reverse proxy. Which Im assuming means I need to forward ports 80 and 443 to the machine running the reverse proxy. I had this all setup and running properly on a digital oceans droplet vps to test setting it up outside my home network.
I need some guidance on what to do next. I’ve done port forwarding before, but not on a router this sophisticated.
