Fallen at the first hurdle!
Hi guys,
Just taken delivery of my 4011 and i am trying to set everything up before i plug it into my internet.
First problem i am having is on the quick setup page, i put in my static ISP internet details, and change the network to the usual 192.168.1.10-254, with the router being assigned 192.168.1.1
Now, for some reason, when i apply the changes, it hands out an IP to my laptop (1.254), but when i try to get access via 1.1 it refuses to connect, so i have to keep doing a hard reset.
I check the network settings, and it is showing the 1.1 defulat gateway etc
That is all i am doing for now and can’t seem to get any further!
Download winbox utility, it has MAC connection mode (so management workstation does not have to be in same IP subnet). After you set things and you loose connectivity, connect using winbox and check if everything is set up correctly.
If you can’t find the problem, open terminal window, execute command
/export hide-sensitive file=export20191207.rsc
, transfer the resulting file (you should find it in Files section) to your PC, open it using text editor, obfuscate your public IP address, any username and password, and then copy-paste it here (use [__code][/code] environment).
Hi and thanks.
Config below.
I will be setting up IPV6 at some point.
Also, Eth1 will be my WAN, with 2-5 as single LAN
add admin-mac=C4:AD:34:55:CB:73 auto-mac=no comment=defconf name=bridge
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.10-192.168.1.250
add address-pool=dhcp disabled=no interface=bridge name=defconf
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add address=192.168.1.1/24 comment=defconf interface=ether2 network=
192.168.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=
ether1
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 name=router.lan
add action=accept chain=input comment=
“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid”
connection-state=invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment=“defconf: masquerade”
/ipv6 firewall address-list
add address=::/128 comment=“defconf: unspecified address” list=bad_ipv6
add address=::1/128 comment=“defconf: lo” list=bad_ipv6
add address=fec0::/10 comment=“defconf: site-local” list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment=“defconf: ipv4-mapped” list=bad_ipv6
add address=::/96 comment=“defconf: ipv4 compat” list=bad_ipv6
add address=2001:db8::/32 comment=“defconf: documentation” list=bad_ipv6
add address=2001:10::/28 comment=“defconf: ORCHID” list=bad_ipv6
add address=3ffe::/16 comment=“defconf: 6bone” list=bad_ipv6
add address=::224.0.0.0/100 comment=“defconf: other” list=bad_ipv6
add address=::127.0.0.0/104 comment=“defconf: other” list=bad_ipv6
add address=::/104 comment=“defconf: other” list=bad_ipv6
add address=::255.0.0.0/104 comment=“defconf: other” list=bad_ipv6
/ipv6 firewall filter
invalid
add action=accept chain=input comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=input comment=“defconf: accept UDP traceroute” port=
33434-33534 protocol=udp
“defconf: accept DHCPv6-Client prefix delegation.” dst-port=546 protocol=
udp src-address=fe80::/10
add action=accept chain=input comment=“defconf: accept IKE” dst-port=500,4500
protocol=udp
add action=accept chain=input comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=input comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
“defconf: drop everything else not coming from LAN” in-interface-list=
!LAN
“defconf: drop packets with bad src ipv6” src-address-list=bad_ipv6
“defconf: drop packets with bad dst ipv6” dst-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: rfc4890 drop hop-limit=1”
add action=accept chain=forward comment=“defconf: accept ICMPv6” protocol=
icmpv6
add action=accept chain=forward comment=“defconf: accept HIP” protocol=139
add action=accept chain=forward comment=“defconf: accept IKE” dst-port=
500,4500 protocol=udp
add action=accept chain=forward comment=“defconf: accept ipsec AH” protocol=
ipsec-ah
add action=accept chain=forward comment=“defconf: accept ipsec ESP” protocol=
ipsec-esp
!LAN
/tool mac-server
/tool mac-server mac-winbox
Ok I gave up trying to reconfigure it in the end.
I have updated to the latest stable release but not really bothered trying again.
The attitude to success is never given up…so, when you were setting up, did you create a user and password? Are you sure it not your browser preventing you? Did you download and try Winbox?
Sorry yes It does seem like I have given up but I haven’t really!
I just needed to get the internet and network back online as soon as I could so I left it at the default for now.
I haven’t yet set up a password, but I did use winbox for the config I posted above!
It’s fairly obvious what the problem was:
/interface bridge port add bridge=bridge comment=defconf interface=ether2
/ip address add address=192.168.1.1/24 comment=defconf interface=ether2 network=192.168.1.0
If you can’t work it out then you need to do some more reading,..
And don’t use Quick Set!
Sorry, new to MikroTik.
And in depth networking, and yes i did use Quickset as it seemed the quickest way to get back up and running.
Not really OP’s fault, seems like there’s a bug in how QuickSet handles setting default LAN address on bridge (could be remnant from the “master port” times).
@jasons6930: follow advice by @sid5632 and don’t ever use QuickSet on this unit again. Then go to IP->address, select address 192.168.1.1/24 and change interface to bridge. Chances are that it’ll start to work afterwards.
Thanks.
Message understood about quick set.
To be honest, i am using Winbox now but still trying to figure it all out!
I knew it was going to be a steep learning curve, but i have heard so many good things about MT, i decided to jump in feet first.
:smiley:
