Falling at the first hurdle
Hi
I have accessed my router and i’m ready to set it up
Looking at the instructions at configuring IP access after i create a bridge
I should configure the bridge port to ether 2
However ether 2 is not in my drop down list only ether 1
Am i missing something?
Thanks in anticipation
Welcome to the forum. So start with the export of your configuration, tell us what device you have, what is your end goal ?
Hi and thanks for your reply
I have a Mikrotik LHGG LTE 6 kit
My goal is to send internet straight from the LTE 6 to my Deco X50 network and distribute from there
Thats it lol
So is there a particular reason you don’t use default configuration ?
If you are a new to Mikrotik and networking maybe it’s best to keep default configuration because you don’t have any protection right now as firewall rules are empty.
Also you don’t have ether2 port because your antenna have only one wired interface.
