Fan on RB433GL
We try to use the fan 5V on RB 433GL but it’s not working. Any idea?
THanks
in v5,18 and older there is a software bug that hides the fan setting from RouterBOARD menu. try to upgrade to v5.19 and check routerboard settings, you should be able to enable the fan there.
Many thanks
