Can someone supply a basic and simple config file to get a routerboard 230 hotspot up and running fast.
It makes sence to provide basic config file to get conectivity, like a plug & play access point that is available in most stores now. :?:
You should use the setup command in the hotspot menu. It is a kind of wizard…
John
Here is a good example in the ‘Documentation’ section of our forum.
http://bruno.pmi.lv/phpbb2/viewtopic.php?t=231
John
