Fasttrack and Fastpath
This document says
https://mum.mikrotik.com/presentations/UA15/presentation_3077_1449654925.pdf
FastPath + Conntrack = FastTrack
Fasttrack is a part of FastPath, it has the same requirements
but this is what I see on my router:
how does fasttrack work without fastpath?
or is the information written in the document incorrect?
No, and no. It needs Fastpath but the status and numbers are not active. If you disable fastpath then fasttrack is also disabled.
