I know that PBR does not play well with Fasttrack. So, I’m trying to exclude “route-marked” packets from being Fasttracked. To my understanding, the following filter rule should pick all packets that were not mangled with route-mark during prerouting:
But, it’s not working. As I understand, route-mark from prerouting should be reflected/available in the forwarding chain (otherwise why having the setting).
If I add a mangle rule to “connection-mark” based on the “route-mark” and use the connection-mark in the Fasttrack filter, it works. But one my setup that requires a few more rules (one for each route mark I use) and the route-mark rules (several) need to passthrough, to allow the connection-marking. Lot’s of rules and not efficient.
Any ideas why checking for route-mark in the forwarding chain will not work?
matches or doesn’t match packets without any routing mark explicitly assigned), there is another point: the
action=fasttrack-connection
rule matches also on received packets which are usually not routing-marked. For this and other reasons, it is much better to use connection marking on both incoming and outgoing connections and translate it to routing marking for outbound traffic. That way, the potentially complex conditions are evaluated only once per connection, when deciding whether to connection-mark its initial packet, and the routing-marking is then applied only on outbound packets and evaluates just a single simple condition
connection-mark=xxx
. The exception from the fasttrack rule is then also based on mere presence or a particular value of connection-mark.
Interesting, my understanding of “route-mark” with a value of “main” is that it means “no routing mark” (if that’s true, why not use “no-mark”). This is very confusing.
Also, I’ve tried using routing-table, without success. Anyone knows when “routing-table” is set?
I will give the idea of conn-mark and then route-mark a try.
The confusion probably comes from the fact that it would be weird to call the default routing table “none”. So an explicit name “main” has been assigned to the default routing table, but you can as well refer to it implicitly by not providing any table name when creating a route. On the other hand, not to assign any routing mark at all to a packet is quite normal, and it may also be useful to check for the mere absence or presence of a routing mark, regardless its actual value if present. Therefore, reserved identifiers “none” and “any” are used to match these two special cases in rules. Use of “any” to indicate the table to which a particular route belongs would be a clear nonsense, and use of “none” to indicate “default” would seem weird as said above, so for naming the default table, both nothing at all (empty name) and main can be used.
(and don’t ask me what happens if you set ****
new-routing-mark=any
or
new-routing-mark=none
EDIT: ignore the text in italics, see newer posts for explanation. I didn’t want to argue with @Sob but I think it makes sense to use
routing-table
in rule chains evaluated after routing has been actually performed, i.e. when the routing table used is already known, like
Please do argue with me, if you think that something I posted is not correct, could be improved, etc. I post either things I’m sure about, or I try to give them at least a quick test. This is the second case.
without any marking, I had “table main” entries in log. And it makes sense to me that when packet is in forward chain and knows outgoing interface (as a result of routing decision), used routing table must be known already.
You’re right about incoming connections, I didn’t think about them.
Well, I should have written “interfere” rather than “argue”, as you were dealing with one part of the issue so I wanted to concentrate only to the other one, i.e. the fasttracking rule “kicking in unexpected” due to matching packets in opposite direction, as one needs to understand how conntrack works to realize that that happens and why.
And you are right that once the packet is being handled by the forward (or input) chain, it must have been routed already, so by my own reasoning the match on ****
Thanks for all the insights. Using connection-marks was my original approach, but I went the other way around: route-mark → connection-mark (not a bright idea)
I run 4 always-on VPN and traffic is routed there based on a combination of source/destination addresses (there are more than 20 rules). I plan to group them by the target VPN circuit and place the corresponding route-mark just after each group. Maybe repeating all the “mark-routing” rules at the beginning can help, as packets other than the first will arrive “connection-marked” so they will skip the bulk of the rules in the chain. Something like:
There is a little overhead for the first packet in a connection, but the rest will be handled by the top rule(s). Traffic that is not touched by the mangle rules will be fasttracked.
Took some time to rewrite all the rules (changing route-marks to connection-marks) adjust passthrough and setting the new route-marks.
So far seems to be working fine.
The idea to add extra connection-mark->route-mark at the top saves most packages from having to traverse the whole chain. Combine this with fasttrack and accept(related,established) and packets will flow with minimal firewall processing.
After connecting and routing marking, I look if a connecting is still NEW so I can fasttrack it. I think this is because of the no passthrough on marking the routing. I mark fasttrack in Mangle.
I am now more adapting rules to how RouterOS/traffic breaths and not that much according to the manual. It is big fun and you can reduce processing time that way.
So when a connection is routing marked and passthrough is no it will leave Mangle without passing through all the lines underneath. The next time the connection passes through mangle to be marked for routing is not new anymore but also on marking it leaves Mangle again and not even reach the fastracking line.
Normally I would also fasttrack on established, not a fan of related, but when I do it on new connections RouteOS only have to mark it once. Even when a connection is fast tracked it will have some slow packet for control and I hope Mikrotik handels the first packets of a fasttracked connection also as slow.
My view of why you don’t want to fasttrack “new” connections is that you want the new connection to first go through your firewall to see if safe/trusted, once the new connection is seens as safe/trusted, the established/related part of that connection can be accepted/fasttracked
That’s how I understand it too. I view fasttracking as a “faster” way to forward related/established packets, so only the first packet needs to suffer through the firewall. With that in mind one does not need to worry to much in optimizing the rules, as most of the packets will skip the firewall chains, except for when using mangle for PBR.
As for being a fan of “related”, my biggest example is SIP. Try it without using “related”. If your SIP client/server is well behaved, you will have to open 10000 port for UDP (if your sw used the 10000-20000 range). WIth “related”, you simply ignore SIP, if running SIP clients only, when the clients register with the external server (on port 5060), “related” will allow all RTP UDP sessions to flow without any need to open ports. And Mikrotik SIP ALG works perfectly, even if you use port forward to bypass ISP SIP filtering. They all require “related” to work.
