Have a setup with LAN full of wired clients, an ubiquity AP that has a vlan1 interface and vlan11 interface (for guest access)
standard interface is bridged into LAN bridge
add fast-forward=no name=Bridge-LAN
add fast-forward=no name=GuestWLANBridge
set [ find default-name=ether1 ] mac-address=name=“ETH1 - Internet”
set [ find default-name=ether2 ] name=“ETH2 - Ubiquity”
/interface vlan
add interface=“ETH2 - Ubiquity” name=“VLAN 11 - Guest” vlan-id=11
add bridge=Bridge-LAN interface=“ETH2 - Ubiquity”
add bridge=GuestWLANBridge interface=“VLAN 11 - Guest”
Have standard fasttrack rules setup and quite standard firewall rules setup
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related” connection-state=established,related
All was working OK until updated to 6.39rc62 (to fix switch hang issue when port flapping).
Now suddenly all wireless clients report their internet access is not working (or is super slow). All clients connected directly to MT via LAN work OK.
Disabling fasttrack rule resolves the problem, so fasttrack got broken somewhere in the way.
Any ideas, or it is a bug?
