Hello Please any Idea why fasttrack is not working after any change in it if i for example disable it and re enable it the role will stop until i reboot the routerboard
that will be fine unless if i want the fasttrack to be controlled by time schedule in this case the disaster that i need to reboot my routerboard every day with 1000 client disconnected and reconnected
any help
Hey again
Fasttrack is a connection property, and behaves lake connection mark. So if fw rule is disabled, the relevant connections are already marked, and as long as they stay alive, they will be fasttracked.
after any change with the role in the fasttrack and apply the role will stop working until i reboot the RB any idea?
