fasttrack conection work in x86 ? yes or not, Mikrotik Know this ???
I bet they know this. But this is an user-to-user forum, so you have to ask MT directly, e.g. by sending them e-mail to support@mikrotik.com .
If you think about what Fasttrack does you will know the answer.
Fasttrack HW-Offloads established connections to the switch-chip, these packets are thereby accelerated by not having to be processed by the CPU. X86 is CPU only - there is no switch chip to offload to. There are specialized hardware that can be installed on x86 systems that can flow-offload but as far as I know they all require their own software and will probably not work with routing software like Router OS for the foreseeable future.
Wrong. It’s one of possibilities, but (currently) it’s a niche use.
Fasttrack was available way before first devices with L3HW offload came to life. The old fasttrack manual page describes its behaviour nicely. The new help system doesn’t have dedicated page for fasttrack, it’s mentioned in fastpath section of packet flow article.
In short: fasttrack allows packets to skip most of packet processing. As to details which parts of packet processing are done with fasttrack enabled it’s Mikrotik to explain. Also particular cases where fasttrack works are MT’s knowledge.
Personally I don’t see any reason for fasttrack not to work on x86. But, as I wrote in my previous psot, it’s MT to tell the truth about it.
I stand corrected. Good to know what actually happens on fasttracked connections.
https://help.mikrotik.com/docs/display/ROS/Packet+Flow+in+RouterOS#PacketFlowinRouterOS-FastTrack
Describes it pretty well - yea, only mikrotik can answer that then.
Not explain if is for x86, you are confused
i think it works but sometimes does not improve performance as much as on a routerboard
fasttrack and now fasttrack6 since 7.18, is a fully software process from routeros.
hardward offloading is different and independant from fasttrack and like say, its performance and availability depend of the hardware.
For what I know, fasttrack is a mikrotik custom solution where the traffic is processed in the driver-layer, and doesn’t need to enter the whole kernel infrastructure. Not to be confused with L3HW acceleration/offload.
My understanding is that there are 2 different aspects behind FastTrack: “action=fasttrack-connection” and “hw-offload=yes”
I believe “action=fasttrack-connection” works on any platform. That is, it goes straight to FastPath. That alone should result in some improvement.
Then the “hw-offload=yes” I think relates to things like integration with the switch chip, which could further cut software steps, but may only be supported on selected MikroTik hardware.
“action=fasttrack-connection” engages “standard” software FastTrack, that should work basically everywhere.
It applies a special flag within the connection tracking mechanism (IP>Firewall>Connections) to make all further packets belonging to this connection bypass a lot of the software steps, saving CPU processing.
“hw-offload=yes” does anything only if you have a device with switch-chip supporting L3HW Offload, and enabled L3HW on it.
It is the “easy option” for using L3HW. Basically, as the fasttrack mechanism “kicks in” it will also program the L3HW features in the chip to process this specific connection bypassing the CPU.
(This however creates an equivalent of a “switch rule” for each hw-fasttracked connection, so it has relatively low limits on the number of total connections which can be offloaded that way at the same time. Manually configured “switch rules” can be designed to apply to a whole category of connections, allowing for much larger amounts of offload to happen.)
Fastpath and Fasttrack generally speaking do NOT work on x86.
It is true that these have nothing whatsoever to do with HW offiload. However, both of these features require specific support to be added to the network interface driver (ethernet chip, etc.). MikroTik only bothers to do this for network interface drivers that apply to interface hardware included with RouterBOARDs. I’ve not yet run into a third-party NIC that is supported by ROS x86 and which is Fastpath/Fasttrack enabled.
Given how much CPU horsepower you can throw at an x86 solution, though, this is generally not an issue (or at least it hasn’t been for us).
I’ve seen significant CPU use reduction from fasttrack on x86 when running a fair number of filter rules in the forward chain, but it isn’t as dramatic as it is on a tile ccr with the interface integration you mentioned.
Do you know how it actually works under the hood?
My guess is that Mikrotik uses their own skb attributes (likely within skb->cb) to flag packets that can bypass things like firewall, NAT, or queuing. This works across all architectures, including x86, and doesn’t require any special driver support.
Btw, if they haven’t already, MT should really consider moving to XDP/BPF since it’s future proof, more flexible and offers better performance.
I have not read through the source code, so no.
I am basing my comments both off of what has been publicly stated, as well as my own observations.
To that last point, if I fire up ROS on x86, populate it with a couple of Intel E1000 interfaces, ensure that Fast Path is enabled and that all requirements are met (e.g. conntrack is turned off and such, no firewall rules, etc.), then IP > Settings will show Fast Path is active, but the counters will remain at 0 and never tick up as packets are forwarded.
Similarly, if on the same router I enable conntrack, add a NAT masquerade rule, and add the appropriate fasttrack-connection action to IPv4 firewall filters, the Fast Path will go inactive, Fast Track will go active under IP > Settings, AND the counters on fasttrack filter rule under IP > Firewall > Filter WILL tick up. But the Fast Track counters under IP > Settings will NOT and will remain at 0.
The documentation for both features both explicitly states that they are only available on certain hardware, AND in some cases only available on select interfaces/ports on certain models (e.g. packets forwarded through either ether12 or ether13 on RB1100 can NOT be Fast Pathed or Fast Tracked, and we know that these two ports on that model are the ones that aren’t directly attached to the SoC but rather are handled by separate NICs hanging off of the PCI bus, as the block diagram in the manual (page 10) clearly shows)! This implies drivers for the interfaces in question (ether1-ether11 in the case of the RB1100) have been specifically patched to add support.
The same documentation also very clearly implies that Fast Track has a dependency on Fast Path…so if a given interface (and, thus, its underlying driver) doesn’t support Fast Path, it won’t support Fast Track, either. Fast Track is described as a Fast Path “handler”:
FastTrack is available > on the devices with FastPath support> . FastTrack is FastPath+Connection Tracking.
(emphasis added)
A MikroTik employee talks about drivers that “support” Fast Path in this post.
On slide 12 of this slide deck from a past MUM talk about Fast Path, it unambiguously states that driver support is a requirement:
FastPath is an > interface driver extension> , that allows you to receive/process/send traffic without unnecessary processing.
● > Interface driver > can now talk directly to specific RouterOS processes - skipping all others
● FastPath requirements:
– > Interface driver support
This post links to this slide deck and makes the same assertions, in a conversation surrounding Fast Path support on RB850Gx2. I can, sadly, confirm through first-hand experience that RB850Gx2 does in fact NOT support Fast Path or Fast Track. All interfaces on 850Gx2 act exactly the same as the E1000 interface does on x86.
In conclusion, specific support needs to be added to hardware drivers before a given interface on a particular router can support Fast Path or Fast Track. I believe this does not prohibit Fast Path support from being added to particular ethernet interface drivers on x86, but it seems clear that MikroTik has not bothered to do so (or if they have, it is to a VERY limited set of drivers…I have not yet run into a common PCI/PCIe ethernet chipset that I can get Fast Path working with on x86).
I should clarify that all of this is very ROS 6 centric. It is possible things have changed in ROS 7.
My take:
Honestly, I think “interface driver extension” most likely refers to using something like the skb->cb control buffer to tag packets internally. That buffer is explicitly designed for storing temporary, per-packet metadata and is commonly used by various subsystems (including Netfilter and QoS) to influence processing without requiring driver-level changes.
From a design standpoint, this approach makes sense: it’s portable across architectures, avoids the need to patch or recompile NIC drivers, and gives Mikrotik full control within ROS itself. I don’t see any strong technical reason why they’d need to modify standard Linux drivers just to implement FastPath/FastTrack.
That said, I’ll concede that “interface driver support” might not necessarily mean modifying the driver. It could just mean that the driver and underlying hardware must not interfere with FastPath requirements — for example, by avoiding PCI bus overhead, allowing DMA forwarding paths, or supporting basic offloads like checksum or TSO. That would explain why some interfaces (e.g. on the RB1100 or RB850Gx2) don’t qualify, even if no actual driver patching is involved.
So no, you still haven’t fully convinced me just yet
but it’s a good discussion!
Eh, maaaaaaybe? But if that were the case, you’d have to validate a lot of things about a potential driver at runtime to make sure it’s safe to support. Assuming this is the case, at that point, if I were MT devs, I would just maintain a whitelist of drivers that were allowed to Fast Path, because otherwise some unexpected implementation or bug in some driver could cause unexpected behavior or problems, even if it otherwise checks all of the boxes.
Anyway, it’s not like it is out of the question, or unheard of, for MT to patch ethernet drivers. They already do so to add L2MTU support. We know L2MTU support is explicitly needed in a driver, because interfaces undergirded by drivers without it just show a ‘0’ as their L2MTU and it remains uneditable…and for such interfaces, the MTU is also treated as the L2MTU. Looking briefly through the RouterOS 6 kernel patch set, they have done very minor updates for minimum L2MTU support on certain drivers for third-party (x86) hardware, like Intel e1000e for example. And yet others bizarrely did not get the same (very minor) treatment, like ixgbe.
So just taking a very extremely brief look at the patches provided by MT (again, on ROS6, so against Linux 3.3.5), I’m not entirely convinced they have supplied us with everything needed to understand Fast Path / Fast Track implementation (though this is at a VERY cursory glance on my part). There is very little matching against ~“fast.*path”.
One thing to note, though, is that the net_device_ops struct in netdevice.h has had a function pointer added to it, named *ndo_fast_path_xmit(). This HIGHLY suggests that a device driver needs to implement that function in order to support Fast Path. Perhaps there is a generic version that it can inherit from, but if so, I haven’t spotted it yet. (There is also a similar function pointer in the same struct called *ndo_change_l2mtu() that presumably needs to be implemented before a particular interface can allow its L2MTU to be set/overridden by the user.)
Although I could see an argument for it being interpreted differently, I would personally say that MT including “Other devices: Not supported” at the end of their table of Fast Path device support is meant to communicate not that “YMMV”, but rather that any device NOT included in that list – which would be inclusive of ALL x86 routers – is a hard “no”.
Hey, good points and nice digging!
It’s fair to point out that Mikrotik has patched drivers, as you mentioned with L2MTU — but that was mostly with ROS 6.x.
When ROS v6 was built on Linux 3.3.5, there were quite a few limitations around L2MTU handling, both in the networking stack and in many drivers. So I fully believe that Mikrotik had to patch drivers more aggressively back then to get things working properly.
But with ROS v7 (now on Linux 5.6.3), full support for L2MTU is present in the kernel via netlink, and most modern drivers already implement the necessary hooks. But some very old drivers — especially legacy Realtek and certain Broadcom variants — might still lack proper L2MTU support if the original vendor hasn’t maintained compatibility with newer kernel APIs. In those cases, Mikrotik likely still needs to patch them manually.
Your discovery of the function pointer in “net_device_ops” called “ndo_fast_path_xmit()” doesn’t automatically mean it’s tied to a deeply patched or nonstandard driver. Quite the opposite — it’s more likely just a Mikrotik-defined standard transiver hook, declared something like this:
struct net_device_ops {
netdev_tx_t (*ndo_fast_path_xmit)(struct sk_buff *skb, struct net_device *dev);
Also, if a driver were responsible for deciding when FastPath should be applied to a packet, that would imply the logic for determining packet eligibility — like whether conntrack is active, NAT is used, firewall rules exist, queues are applied, etc — would have to live inside the driver. That seems both architecturally awkward and hard to scale. It would essentially mean that every NIC driver ROS uses would need to be massively reworked, which feels unlikely and unnecessarily complex.
Your observations (e.g. counters staying at zero) might also suggest that the FastPath metrics themselves aren’t being reported correctly — rather than FastPath not working at all. The fact that ROS reports FastPath as enabled on x86 even if counters stay at 0 still suggests that the mechanism is present and able to engage.
Also, in general I wouldn’t necessarily interpret “Other devices: Not supported” as meaning will never work. Mikrotik’s documentation is infamously vague and sometimes directly contradictory when it comes to technical internals.
To me, the key question still is: Does FastPath require a hard dependency on patched drivers, or can ROS use skb with standard hooks? I’m still convinced it’s the latter — meaning this can be abstracted internally without invasive driver changes.
Appreciate the detailed response though!
Yes, of course. That’s what we are discussing.
Unfortunately, at the moment, I feel that we (on the outside of MT engineering) lack enough evidence to definitively say one way or the other, and that we can both be looking at the available evidence and yet still reasonably come to the exact opposite conclusion.
For example…
...I do not see your conclusion here as inescapable. I could just as easily argue that Fast Path and Fast Track reporting in ROS is merely an indicator that all of the "soft" requirements have been met (that is, there is no user config -- e.g., firewall filter rules, etc. -- that would stand in the way of it working, [u]_were it actually supported on the hardware itself_[/u]), and not that it is a definitive sign that Fast-Path-ing is actually happening. The RB850Gx2, which infamously does not support Fast Path, will _[u]also[/u]_ show "ipv4-fast-path-active: yes" or "ipv4-fast-track-active: yes" as long as [these](https://wiki.mikrotik.com/Manual:Fast_Path#IPv4_handler) . [conditions](https://wiki.mikrotik.com/Manual:IP/Fasttrack#Requirements) are met.
I will give you that one. 😂
I hadn't heard this / wasn't aware of a new L2MTU support being added to more recent mainline Linux releases, but even if that is true, as far as I can tell from looking at MikroTik's patches to 5.6.3, they don't seem to be making use of whatever new "native" L2MTU support there is. Most of their custom/in-house L2MTU stuff that existed in their 3.3.5 patches appears to have been dropped in place almost verbatim (+ there is some new "MPLSMTU" stuff that is implemented much the same way).
I am admittedly nowhere near a Linux kernel internals expert, even less so on the network stack side. That said, it still seems like more than that is actually going on, though I could be vastly misinterpreting things here (see: previous sentence).
Here is the actual definition of the function under discussion:
int (*ndo_fast_path_xmit) (struct net_device *dev, struct fp_buf *fpb);
So calls to this are not just passing a standard sk_buff along with the device struct, but rather some other packet buffer (meta?-)structure, which is also (seemingly) brand-new. _**Frustratingly**_, I cannot find the actual definition of this struct ANYWHERE within either MT's patchset, or within a full Linux source tree that the patch has been applied to. It is forwardly declared within the patch, immediately before the beginning of the net_device_ops struct definition, so that the struct type can be referenced as a parameter to be passed to the fast_path_xmit function...
struct fp_buf;
…but that’s all she wrote. The actual definition of the struct and its members is nowhere to be found. I mean, I suppose it’s possible that this could be getting aliased to sk_buff itself, but we simply don’t know!
There are several other Fast Path related structures, whose names all begin with ‘fp_’, and many of which are also missing definitions, with the notable exception of fp_dev (it appears all of the others are being forward-declared because there are members of fp_dev made of those struct types):
struct fp_stuff;
struct fp_dev_pcpu_stats;
struct fp_stats_rcu;
struct fp_dev {
struct fp_stuff *stuff;
int (*xmit)(struct net_device *dev, struct fp_buf *fpb);
struct hlist_node list;
struct fp_dev_pcpu_stats __percpu *stats;
struct fp_stats_rcu *stats_rcu;
u64 sp_rx_packet;
u64 sp_tx_packet;
u64 sp_rx_byte;
u64 sp_tx_byte;
u64 fp_rx_packet;
u64 fp_tx_packet;
u64 fp_rx_byte;
u64 fp_tx_byte;
u64 tx_drop;
So we see what look like a bunch of stats/counter variables, and an ambiguous “stuff” structure, heh. It also sure looks like that same ndo_fast_path_xmit() function is being pointed at within the fp_dev struct, too, just under a different (shorter) name…
The fp_dev struct gets instantiated within the net_device struct:
struct net_device {
unsigned devid;
struct fp_dev fp;
unsigned long list_bitmap[256 / BITS_PER_LONG];
…and yet I cannot find a single place in the whole of the Linux source tree where dev.fp / dev->fp is ever touched or referenced.
There are also a bunch of other Fast Path related functions declared in include/linux/netdevice.h…
extern void (*fp_ptype_all_changed)(int);
extern void (*fp_nf_changed)(int, int pf);
extern void (*fp_xfrm_changed)(int);
...which are getting exported out of net/core/dev.c. Except that **_[u]the actual code for all of these functions is completely missing, too![/u]_**:
void (*ipv4_routing_changed)(void);
EXPORT_SYMBOL(ipv4_routing_changed);
EXPORT_SYMBOL(fp_ptype_all_changed);
EXPORT_SYMBOL(fp_nf_changed);
EXPORT_SYMBOL(fp_xfrm_changed);
There are a handful of calls being made to these functions that I can find scattered around, but no backing code. That’s all that exists.
Finally, there is one additional function pointer that was added to net_device_ops right below the fast_path_xmit one:
int (*ndo_xmit_commit) (struct net_device *dev);
I don’t actually know that it is Fast Path related, but…probably?
In any case, I cannot find a single implementation of either ndo_fast_path_xmit or ndo_xmit_commit ANYWHERE, either. So either I’m blind as a bat, or MikroTik seemingly left a bunch of applicable code out of its GPL kernel patches.
As an interesting side note, I had a set of kernel patches laying around from a 6.5 release candidate, and ndo_fast_path_xmit actually used to be defined this way:
netdev_tx_t (*ndo_fast_path_xmit) (struct net_device *dev, struct net_device *port, void *buf);
Yeah, but you forgot to add my mighty conclusion: I’m still convinced it’s the latter — meaning this can be abstracted internally without invasive driver changes.. ![]()
ps…
You don’t need to use a backtick to add an empty new line, just use a space plus newline, like this:
start
end
