Fatal error No HardDrive
Hello i am trying to install mikrotik on a server prolian Dl380 so ti can support a large user size on a pppoe server
but when i try to install mikrotik i cannot pass looking for harddrive an fail
i need hel to proceed to the installation
i was use to use old pc but this time i am trying to install mikrotik on a reel server thanks for the help it could be a driver problem thanks
gabsky
Try setting “SATA Mode” to “Compatibility” or similar.
If it doesn’t work, you can also install RouterOS in a USB drive
I think your server has an internal USB port, ideal for this. Almost all HP servers has it
Regards
