hi
i want to knows what is kind of fax cards which mikrotik supported it?
and i have ADSL LINE i want to know how configuration mikrotik to work without ADSL MODEM by add fax card to mikrotik ?
and how can i mix two ADSL LINE in mikrotik ?
thanks
as far as i know ROS doesn’t support any PCI or USB adsl modems
you should use external ADSL Router
but when i read mikrotik manual it support fax pci cards or PCI ISDN cards but i want to know what chipset support
iam from egypt
hitham_adel2004@hotmail.com
There is big deferent between FAX Modem (Dialup Modem) and internal ADSL Modem Card.
And from your post before I think that you are talking about Internal ADSL Modem (PCI Card)
And Mikrotik don’t support PCI ADSL Cards.
read this please i copied it from manual
Xpeed SDSL Interface
Document revision 1.1 (Fri Mar 05 08:18:04 GMT 2004)
This document applies to MikroTik RouterOS V2.9
Table of Contents
Table of Contents
General Information
Summary
Specifications
Related Documents
Additional Documents
Xpeed Interface Configuration
Property Description
Example
Frame Relay Configuration Examples
MikroTik Router to MikroTik Router
MikroTik Router to Cisco Router
Troubleshooting
Description
General Information
Summary
The MikroTik RouterOS supports the Xpeed 300 SDSL PCI Adapter hardware with speeds up to
2.32Mbps. This device can operate either using Frame Relay or PPP type of connection. SDSL
(Single-line Digital Subscriber Line or Symmetric Digital Subscriber Line) stands for the type of
DSL that uses only one of the two cable pairs for transmission. SDSL allows residential or small
office users to share the same telephone for data transmission and voice or fax telephony.
Specifications
Packages required: synchronous
License required: level4
Home menu level: /interface xpeed
Standards and Technologies: PPP (RFC 1661) , Frame Relay (RFC 1490)
Hardware usage: Not significant
Related Documents
• Package Management
• Device Driver List
• IP Addresses and ARP
• Xpeed SDSL Interface
Page 292 of 695
Copyright 1999-2007, MikroTik. All rights reserved. Mikrotik, RouterOS and RouterBOARD are trademarks of Mikrotikls SIA.
Other trademarks and registred trademarks mentioned herein are properties of their respective owners.
• Xpeed homepage
name ( name ) - interface name
mtu ( integer ; default: 1500 ) - Maximum Transmission Unit
mac-address ( MAC address ) - MAC address of the card
arp ( disabled | enabled | proxy-arp | reply-only ; default: enabled ) - Address Resolution Protocol
• disabled - the interface will not use ARP protocol
• enabled - the interface will use ARP protocol
• proxy-arp - the interface will be an ARP proxy
• reply-only - the interface will only reply to the requests originated to its own IP addresses, but
neighbor MAC addresses will be gathered from /ip arp statically set table only
mode ( network-termination | line-termination ; default: line-termination ) - interface mode, either
line termination (LT) or network termination (NT)
sdsl-speed ( integer ; default: 2320 ) - SDSL connection speed
sdsl-invert ( yes | no ; default: no ) - whether the clock is phase inverted with respect to the
Transmitted Data interchange circuit. This configuration option is useful when long cable lengths
between the Termination Unit and the DTE are causing data errors
sdsl-swap ( yes | no ; default: no ) - whether or not the Xpeed 300 SDSL Adapter performs bit
swapping. Bit swapping can maximize error performance by attempting to maintain an acceptable
margin for each bin by equalizing the margin across all bins through bit reallocation
bridged-ethernet ( yes | no ; default: yes ) - if the adapter operates in bridged Ethernet mode
dlci ( integer ; default: 16 ) - defines the DLCI to be used for the local interface. The DLCI field
identifies which logical circuit the data travels over
lmi-mode ( off | line-termination | network-termination | network-termination-bidirectional ;
default: off ) - defines how the card will perform LMI protocol negotiation
• off - no LMI will be used
• line-termination - LMI will operate in LT (Line Termination) mode
• network-termination - LMI will operate in NT (Network Termination) mode
• network-termination-bidirectional - LMI will operate in bidirectional NT mode
cr ( 0 | 2 ; default: 0 ) - a special mask value to be used when speaking with certain buggy vendor
equipment. Can be 0 or 2
Example
To enable interface:
Page 293 of 695
[admin@r1] interface> print
Flags: X - disabled, D - dynamic, R - running
NAME TYPE MTU
0 R outer ether 1500
1 R inner ether 1500
2 X xpeed1 xpeed 1500
[admin@r1] interface> enable 2
NAME TYPE MTU
2 R xpeed1 xpeed 1500
Consider the following network setup with MikroTik router connected via SDSL line using Xpeed
interface to another MikroTik router with Xpeed 300 SDSL adapter. SDSL line can refer a common
patch cable included with the Xpeed 300 SDSL adapter (such a connection is called Back-to-Back).
Lets name the first router r1 and the second r2.
Router r1 setup
The following setup is identical to one in the first example:
[admin@r1] ip address> add inter=xpeed1 address 1.1.1.1/24
[admin@r1] ip address> pri
ADDRESS NETWORK BROADCAST INTERFACE
0 1.1.1.1/24 1.1.1.0 1.1.1.255 xpeed1
[admin@r1] interface xpeed> print
Flags: X - disabled
0 name="xpeed1" mtu=1500 mac-address=00:05:7A:00:00:08 arp=enabled
mode=network-termination sdsl-speed=2320 sdsl-invert=no sdsl-swap=no
bridged-ethernet=yes dlci=16 lmi-mode=off cr=0
Router r2 setup
First, we need to add a suitable IP address:
[admin@r2] ip address> add inter=xpeed1 address 1.1.1.2/24
[admin@r2] ip address> pri
0 1.1.1.2/24 1.1.1.0 1.1.1.255 xpeed1
Then, some changes in xpeed interface configuration should be done:
[admin@r2] interface xpeed> print
Flags: X - disabled
[admin@r2] interface xpeed> set 0 mode=line-termination
Now r1 and r2 can ping each other.
Page 294 of 695
Let us consider the following network setup with MikroTik Router with Xpeed interface connected
to a leased line with a CISCO router at the other end.
MikroTik router setup:
Flags: X - disabled
bridged-ethernet=yes dlci=42 lmi-mode=off cr=0
Cisco router setup
CISCO# show running-config
Building configuration...
Current configuration...
ip subnet-zero
no ip domain-lookup
frame-relay switching
interface Ethernet0
description connected to EthernetLAN
ip address 10.0.0.254 255.255.255.0
interface Serial0
description connected to Internet
no ip address
encapsulation frame-relay IETF
serial restart-delay 1
frame-relay lmi-type ansi
frame-relay intf-type dce
interface Serial0.1 point-to-point
ip address 1.1.1.2 255.255.255.0
no arp frame-relay
frame-relay interface-dlci 42
end.
Send ping to MikroTik router
CISCO#ping 1.1.1.1
Type escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/31/32 ms
CISCO#
Troubleshooting
Description
Page 295 of 695
Other trademarks
First of all Xpeed 300 PCI is SDSL modem and use Frame Relay encapsulation and you talk about ADSL and this days ADSL use ATM encapsulation
Second Xpeed company withdrawal its business in 2002.
Back in 2000 when we start to offer DSL in Egypt we use Xpeed 320r, Xpeed 320 Xpeed 300 and it was the worst hardware ever. (no wonder that company don’t exist any more)
So if ROS is support Xpeed 300 (I think ROS ver. 3 doesn’t support this card) that doesn’t mean ROS support ADSL PCI card
You can check
http://forum.mikrotik.com/t/support-for-pci-adsl-cards/17027/1
http://forum.mikrotik.com/t/can-router-os-aggregate-adsl-links-for-load-balancing/20567/1
http://forum.mikrotik.com/viewtopic.php?f=3&t=18762&start=0&st=0&sk=t&sd=a&hilit=adsl+pci
and you can vote for you request at
http://wiki.mikrotik.com/wiki/MikroTik_RouterOS/v3/Feature_Requests
really thanks about your information
and i want to know what is ROS V3
and i want to know what i need to working with adsl modems cards
i use mikrotik 2.9.27
thanks
ROS v3 in Mikrotik RouterOS version 3.X
there is no way to add drivers to Mikrotik RouterOS so you cant install any device that Mikrotik dosn’t support it.
This forum is for legal copies of Mikrotik RouterOS, you can’t just use hacked version and ask here for support, buy a license, it will cost you only 45$, nearly 235 LE, it’s cheaper than some ADSL routers
After that all member of this forum and also official Mikrotik support are ready to help you
Ok, I have to get a fax machine at home but dont want to use the handset part of it to answer calls. Can I still use my cordless phone for making and answering calls? I don’t want to add another phone-jack if I can help it. My fax machine has a USB connection free. The phone system is a Panasonic 6.0 system. Is there a USB converter of something? Is there a way to connect a fax machine to a cordless phone system?
