Same as before. Running server on FC5. Slow response when using the client on the server. Running the client on a windows box to the server works well. Running the client on a FC5 box to the server, the map loads but doesn’t update after it is loaded. Charts do not work. This is with beta3.
Also found that after trying it with an FC5 client if I went back to the windows box it shows connected but map never shows. If I go to the server and start the client then close it, the windows box then works.
tk
