FCC limit for WiFi AP
scenario::
i have just ordered a groove A-2hn AP (631mW output)
and a 15dBi omni antenna
connecting the ap directly to ant. (no cable loss)
using formula to calc EIRP i get 19.954 Watts
EIRP = P ´ 10 dBi/10
(P = transmitter-amp power in Watts. dBi = gain in dBi - cable attenuation in dB. This result is in Watts.)
or EIRP = P - A + G
(P = transmitter-amp power in dBm, A = Atennuation in dB, G = Gain in dBi. The result is in dBm)
question::
is this legal by FCC. everything i found says…
2.2 Part 15.247
Devices that operate to FCC Part 15.247 are limited to frequency hopping and digitally modulated
systems.
2.2.1 Digital Modulation System Requirements
The FCC, under the definition of systems using digital modulation techniques, allows a device to
comply with these regulations without necessarily implementing Direct Sequence Spread Spectrum
(DSSS), provided that the following requirements are met:
  1. The minimum 6 dB bandwidth of the signal shall be at least 500 kHz.
  2. The maximum permitted peak conducted output power is +30 dBm (1 W). However, the
    power spectral density conducted from the intentional radiator to the antenna shall not be
    greater than +8 dBm in any 3 kHz band during any time interval of continuous transmission.
  3. If the antenna used has a directional gain in excess of 6 dBi then the conducted output power
    described shall be reduced by the amount in dB that the directional gain of the antenna
    exceeds 6 dBi.
  4. In any 100 kHz bandwidth outside the frequency band of operation the power shall be at least
    20 dB below that in the 100 kHz bandwidth within the band that contains the highest level of
    the desired power.
  5. Radiated harmonic and spurious emissions which fall within the restricted bands, as defined
    in FCC Part 15.205, must comply with the radiated emission limits specified in FCC Part
    15.209.
which only defines “directional antenna” where mine is an omni.
should i be ok with this or will i have to turn down the power.
also i remember in the routerOS that you had to set the Country.
i first assumed that it was only for which frequencies were available, but now im wondering …
it knows the output power of the AP and you specify your antenna gain. using that does the routerOS regulate the AP to stay within the FCC limits. (long shot but a guess)
any help or reference is appreciated.
i searched the forum and net and found similar answers but nothing that will lay this question of mine to rest
4W EIRP
36dB
If you have a grid, point to point shot, then you have to reduce tx power 1dB for every 3dB gain over 6dBi antenna with 30dB transmitter. Anything more than 2 radios involved in the link means it is point to multipoint, the AP is allowed 4W or 36dB, the clients can use point to point rules.
Essentially, any radio with an omni, regardless of how you are connecting, is limited to 4W.
With a 15dBi omni, legally in FCC land you can only use 21dBm tx power. 19W is highly illegal and, according to just about any and all Wireless ISPs, essentially peeing in the pool.
If you put the antenna gain on the Wireless tab and set Frequency mode to regulatory, country set to US, it should limit you accordingly, but if memory serves it limits 2.4GHz and 5.8GHz to 1W while legally we’re allowed 4W.
