Hello there,
I’m using a CCR1009 as “core” router, and a RB4011iGS+ as “edge” router.
Both are connected through their sfp-sfpplus1 interface.
I’m using two SPF+ modules: SFP-10G-BXU on one side (https://www.fs.com/fr/products/36351.html) and one SFP-10G-BXU (https://www.fs.com/fr/products/36353.html) on the other.
Problem is: I’ve to reboot the RB4011 on a daily basis because I got tons of “fcs error on link” in CCR1009 logs, every 30 seconds exactly.
On RB4011 side, I got sfp-sfpplus1 interface going down then up, again and again.
I’ve enabled the flow control on both sfp-sfpplus1 interfaces, without any changes.
Here’s the monitor output for both SFP+ interfaces:
status: link-ok
auto-negotiation: disabled
rate: 10Gbps
full-duplex: yes
tx-flow-control: yes
rx-flow-control: yes
sfp-module-present: yes
sfp-rx-loss: no
sfp-tx-fault: no
sfp-type: SFP-or-SFP+
sfp-connector-type: LC
sfp-link-length-9um: 10000m
sfp-vendor-name: FS
sfp-vendor-part-number: SFP-10G-BX
sfp-vendor-serial: F2010693887
sfp-manufacturing-date: 19-12-04
sfp-wavelength: 1330nm
sfp-temperature: 64C
sfp-supply-voltage: 3.303V
sfp-tx-bias-current: 61mA
sfp-tx-power: -2.21dBm
sfp-rx-power: -2.937dBm
eeprom-checksum: good
and
status: link-ok
rate: 10Gbps
full-duplex: yes
sfp-rx-loss: no
sfp-tx-fault: no
sfp-vendor-name: FS
sfp-vendor-serial: G2002252237
sfp-manufacturing-date: 20-07-29
sfp-wavelength: 1270nm
sfp-temperature: 38C
sfp-supply-voltage: 3.257V
sfp-tx-bias-current: 30mA
sfp-tx-power: -2.088dBm
sfp-rx-power: -5.561dBm
Next step I see is to change SFP+ modules, one after the other.
Any suggestion welcomed,
Have a nice day
