Feature/Bugfix required: UPNP
Hello, there’s a few problems with Mikrotik UPNP:
  1. The UPNP rules not working after WAN IP changed: http://forum.mikrotik.com/t/problem-with-upnp-portforwarding/99985/5
    The UPNP rules are bounds to WAN IP only by default, not the WAN interface.
    I found a solution in the post, but that need manual setup, so all rules made by programs(torrent etc.) automatically are still suffering.
  2. All UPNP rules are persist until manual remove or reboot.
    As most program don’t remove UPNP rules on exit, this could be a mess after a long uptime, there’s always tons of unused rules, and they can only removed manually.
    When combine with problem 1, this is even worse, many rules are completely dead after a WAN IP change, but they still remains.
    There should be a option for UPNP rules timeout, those rules older than that would be auto removed.
Thank you for reading and hope Mikrotik would see this, it’s not fatal but really annoying.
I am also the same problem, hope mikrotik can see and solve this problem.
