Feature Req: IKEv2 server and client
Please make it possible :smiley:
It is planned in ROS v7
When is it planned we can test ROS v7 ?
When it’s ready :slight_smile:
touché
:slight_smile:
We are in desperate need of using the Mikrotik as an IKEv2 VPN member. Is there an ETA on this feature?
We have an infrastructure based the mikrotik routers. Now, we need to connect our network with Microsoft Azure Network. Is required to use IKEv2 for establish IPSec tunnel.
We hope that ROSv7 will appear in brief with IKEv2 support.
Thanks.
+1 here. Many clients need it.
Windows Phone 8/8.1 has all but done away with PPTP & LT2P :frowning:. The only VPN protocol supported on these devices is IKE v2 (what were you thinking Microsoft?), thus the desperation for IKE v2 VPN server in RouterOS. Please add it soon, at least give us an ETA so we know not to waste time on alternate solutions.
Definitely needed! Desperately.
Any word on a timeline for ros7? This is needed so badly.
This is needed! Any update for ETA on this feature?
+1 for IKE v2-----very much needed
I do not consider that answer by Mikrotik staff as respectful. I do not think it is funny to reply in this way to paying customers.
As I was also in need for IKEv2, I has resolved it with OpenWRT. StrongSwan works well there. You can use any router, not only Mikrotik.
I guess Mikrotik is happy with itself. Mikrotik devices interconnects perfectly with other Mikrotik devices. But we need more than this. And nowadays IKEv2 is imperative. So Mikrotik should make the costumer’s priority his priority. Once ROSv7 has not a release date yet and we are committed with clients, we cannot continue telling them that IKEv2 will be in ROSv7 without a date. As this undefined date is too distant, Mikrotik should release IKEv2 still on ROSv6. We can’t wait more. Please, hurry up!
Completely agree. If there’s going to be extended delays in getting v7 then Mikrotik need to look at bringing forward some features to the current version.
With such a promising and growing product, it’s very important to also not lapse behind current technology.
+1.
Before IKEv2 is stable in ROS7 one can use metarouter and install OpenWRT image and use it for IKEv2 setup.
I know it’s not as straightforward as having it supported by mikrotik box itself but I think it will take some time before IKEv2 will be mature enough to be used in production.
Just my 2 cents… :slight_smile:
+1
IKEv2 is necessary to connect local net to Azure with dynamic routing. I hoped to recommend my customers Mikrotik, but 3 years past, it not supports IKEv2.
+1
I also need it for connecting to the dynamic gateway in Azure.
Please! ikev2 ASAP.
