Feature Req: IKEv2 server and client
+1
It’s time for IKEv2
+1
IKEv2 support would be great
+1
when does MikroTik implement IKEv2?
As it was mentioned earlier in this topic
ROS v7.
by mrz » Thu Oct 16, 2014 11:23 am
my grandpa hopes to see ROS7 before he died
when can we test ROS7 with ikev2 server
More than one year later…
IKEv2 is very needed. We have infrastructure in Azure, can’t use route based vpn ((((
My 2 Cents is that V7 is a Unicorn.
If one read the forum and all that V7 will fix… Good Dam… No company in history has ever managed to release such a big overhaul.
IkeV2 is the new standard in almost all communications between organisations. We NEEEEEEEEEEEEEEEEED it.
If not in the V6 branch then release a scaled down R7 Brach with only a work in progress specific feature set. The problem is not that one can’t afford another mikrotik box to solve problem as you would need to get that version in a separate system. But then again as the situation is now it is not solvable at all with mikrotik.
Don’t come barking with use meta this and that. There is a whole other ton of considerations before deploying a new “other” system.
I honestly like all with mikrotik except this Unicorn V7 crap.
but every kid knows: unicorns are COOL.
so ROS 7 had to be too :wink:
I work in Healthcare, with more than 250 companies including all of the insurance companies, and 13 hospitals.. Not a single one uses IKEv2. Not even testing it. As far as healthcare and insurance is concerned, IPSec with PFS is still the standard.
I am also waiting for IKEv2 support from MikroTik, but caught between deploying EdgeRouters with IKEv2 or L2TP+IPSec on Mikrotik.
+1 here, also in need of IKEv2.
As many others before me, I’m needing to connect an Azure network with virtual machines to another facility where we have servers. Azure is using IKEv2 and I don’t see any way to downgrade it or use another option. I also have an entire network using MikroTik devices and feel reluctant to change products. A new product means a new learning curve, new skills to develop and new problems to discover and solve.
Please MikroTik guys, we’re counting on you!
Thank you
Azure works also with IKEv1. So until v7 is released you can set up tunnels with ikev1.
When using Azure with multi-site vpn, you need IKE V2 :frowning:
+1 for IKEv2 support
What is the planned release date of ROSv7?
I guess ROS v7 with the begged IKEv2 will came just after ROS v6.999. We are still on ROS v6.37, so patience …
You are so optimistic, maybe it will be v6.9999
Apple IOS 10.x just pulled PPTP support. But they support IKEv2 for long time now.
Hello !
I need to make many IPv6 IPSEC Tunnels between a datacenter that has an Zywall.
There is only IKEv2 supported for IPv6 tunnels on a Zywall.
So you tell me that I have to buy crappy Zywall to do it ? :frowning:
Any other solutions ?
Since Mikrotik does not currently support IKEv2 is there any other inexpensive and easy to setup solution until we get support in Mikrotik?
+1 It’s been over a year now
