Please make a Winbox version for linux.
I know it works with wine because I use it.
Problem is with graphics. When Use terminal from winbox it is so hard to use cursor because character not coresponding.
Regards,
Regards,
I use Winbox through WINE every day and don’t have the problem you are reporting. If it is in depth terminal/CLI then I prefer to SSH in.
There can be problems with fonts if you do not have windows font package installed, you have applied some custom theme, or adjusted font sizes to non default values.
Crossover can be an anternative too:
