Feature Request: 6VPE (VPNv6) - ipv6 address family
In BGP table, yes, but not in RIB:
ASR1000#show bgp vpnv6 unicast vrf VRF_A 2001:xxxx:800:4700::/56
BGP routing table entry for [65001:40]2001:xxxx:800:4700::/56, version 2914773
Paths: (1 available, best #1, table VRF_A)
  Not advertised to any peer
  Refresh Epoch 1
  65000, imported path from [65000:1009301]2001:xxxx:800:4700::/56 (global)
    ::FFFF:10.0.6.103 (via default) from *10.0.6.103 (10.37.28.254)
      Origin incomplete, metric 0, localpref 100, valid, external, best
      Extended Community: RT:65001:40
      mpls labels in/out nolabel/21
      rx pathid: 0, tx pathid: 0x0
      Updated on May 2 2024 09:53:21 CEST
ASR1000#show ipv6 route vrf VRF_A 2001:xxxx:800:4700::/56
Routing entry for 2001:xxxx:800:4700::/56
  Known via "bgp 65001", distance 20, metric 0
  Tag 65000, type external
  Route count is 1/1, share count 0
  Routing paths:
    10.0.6.103%default indirectly connected
      Route metric is 0, traffic share count is 1
      MPLS label: 21
      MPLS Flags: NSF
      From A00:667:817:2229:4F7F:80:E000:66
      opaque_ptr 0x7F4F320D0F00
      Last updated 5w1d ago
Something still missing but I not yet figured it out what it is.
RFC 4659 said:
3.2.1.2. BGP Speaker Requesting IPv4 Transport
When the IPv6 VPN traffic is to be transported to the BGP speaker
using IPv4 tunneling (e.g., IPv4 MPLS LSPs, IPsec-protected IPv4
tunnels), the BGP speaker SHALL advertise to its peer a Next Hop
Network Address field containing a VPN-IPv6 address:
  • whose 8-octet RD is set to zero, and
  • whose 16-octet IPv6 address is encoded as an IPv4-mapped IPv6
    address [V6ADDR] containing the IPv4 address of the advertising
    BGP speaker. This IPv4 address must be routable by the other
    BGP Speaker.
And in sniffed traffic it seems it is correct:
And this IPv4 address is routable by the opponent router:
[admin@rtr1.CPE] > /ip/route/print where dst-address=10.0.10.12
Flags: D - DYNAMIC; A - ACTIVE; b - BGP, o - OSPF
Columns: DST-ADDRESS, GATEWAY, DISTANCE
    DST-ADDRESS    GATEWAY          DISTANCE
D b 10.0.10.12/32  10.0.10.12            200
DAo 10.0.10.12/32  10.0.1.1%ether2       110
[admin@rtr1.CPE] >
But the mapped address is unreachable. If I create a static route for that mapped address the VPN routes comes up:
[admin@rtr1.CPE] > /ipv6/route/print where bgp-mpls-vpn
[admin@rtr1.CPE] > /ipv6/route/add dst-address=::ffff:10.0.10.12 gateway=fe80::a00:27ff:fe00:4101%ether2
Flags: D - DYNAMIC; A - ACTIVE; y - BGP-MPLS-VPN; H - HW-OFFLOADED
DAyH b00b::10:12:11:0/112  ::ffff:10.0.10.12       200
DAyH b00b::10:12:12:0/112  ::ffff:10.0.10.12       200
[admin@rtr1.CPE] >
But it is not working:
[admin@rtr1.CPE] > ping vrf=VRF_A_ b00b::10:12:11:1
  SEQ HOST                                     SIZE TTL TIME       STATUS
    0                                                              22 (Invalid argument)
    1                                                              22 (Invalid argument)
    2                                                              22 (Invalid argument)
    sent=3 received=0 packet-loss=100%
[admin@rtr1.CPE] > ping vrf=VRF_A_ b00b::10:12:11:1 src-address=b00b::10:11:11:1
Correct me if I’m wrong, but that is not supposed to work. Mapped ipv4 address is just a representation of IPv4 address in a specific format to be able to store it in ipv6 database. It cannot be used as real address or to be routed.
In RouterOS routes with such a gateway will always be unreachable because mapped ipv4 is not considered a valid routable gateway. Linux does not allow to add in the FIB ipv6 routes with ipv4 mapped gateways, too.
So previous suggestions still are the only reasonable ones.
And regarding routing filter not working, you cannot set ipv4 gateway to ipv6 route, that is invalid configuration. For ipv6 route you need ipv6 gateway.
Even on cisco forums they have similar suggestions:
see Gopinath_Pigili post:
https://learningnetwork.cisco.com/s/question/0D56e0000D9w5pFCQQ/bgp-ipv6-routing-over-an-ipv4-bgp-session
Hi mrz,
Thanks so much to digging these out. If I’m right, if I use VPNv6 over IPv6 I should use LDPv6 for IPv6 nexthops.
I don’t understand yet how should VPNv6 over IPv4 exactly works. I’ll try to investigate this.
So, If I’m right, it should works as mentioned above. BGP neighbors and LDP neighbors is communicating over IPv4, so VPNv4 route’s nexhop is plain IPv4 addresses and VPNv6 (over IPv4) route’s nexthop is mapped IPv4 address. This documents also referring this:
https://www.cisco.com/c/en/us/support/docs/ip/ip-version-6/112085-ipv6-over-mpls-vpn-00.html
Mapped nexthop is only in BGP table.
And this is one of our backbone routers outputs:
ASR1000#show bgp vpnv6 uni vrf VRF_A 2001:xxxx:800:2900::/56
BGP routing table entry for [65001:40]2001:xxxx:800:2900::/56, version 3240189
  Refresh Epoch 1
  Local, imported path from [65001:54]2001:xxxx:800:2900::/56 (global)
    ::FFFF:10.20.97.230 (metric 81) (via default) from 10.20.97.92 (10.20.97.92)
      Origin incomplete, metric 0, localpref 222, valid, internal, best
      Originator: 10.20.97.230, Cluster list: 10.20.97.92
      mpls labels in/out nolabel/379
      Updated on Jun 6 2024 14:02:57 CEST
ASR1000#show ipv6 cef vrf VRF_A 2001:xxxx:800:2900::/56 detail
2001:xxxx:800:2900::/56, epoch 0, flags [rib defined all labels]
  recursive via 10.20.97.230 label 379
    nexthop 10.20.111.227 HundredGigE0/0/0 label 24145-(local:5403)
    nexthop 10.20.111.229 HundredGigE1/0/0 label 24242-(local:5403)
ASR1000#show mpls forwarding-table vrf VRF_A 2001:xxxx:800:2900::/56
Local      Outgoing   Prefix           Bytes Label   Outgoing   Next Hop
Label      Label      or Tunnel Id     Switched      interface
None       379        2001:xxxx:800:2900::/56[V]   \
                                       0             Hu1/0/0    10.20.111.229
ASR1000#
I don’t know what process translate between mapped IPv4 BGP nexthop and IGP native IPv4 nexthop. If I understand what mrz wrote RouterOS can’t do this due to the Linux nature of RouterOS?
Furthermore if I change the nexthop to global scoped IPv6 address then I need IGP and LDP over IPv6 to nexhops and this is not exists in our setups.
Now I can understand that @oreggin is pointing out that the current 6VPE implementation of ROS does not support section 3.2.1.2 of RFC 4659 “BGP Speaker Requesting IPv4 Transport” https://www.rfc-editor.org/rfc/rfc4659.html#section-3.2.1.1. It’s really a shame because that is perhaps the most interesting functionality of 6VPE.
Regarding what @mrz raises about Cisco, Gopinath_Pigili’s comment refers to a double stack BGP session over IPv4. Section 3.2.1.2 of RFC 4659 is fully supported by Cisco in its various IOS. In fact, this and other manufacturers present 6VPE as the way to provide IPv6 services over an MPLS IPv4 backbone.
I don’t think its a shame. It is not a problem, it is a task :wink:
If I’m right, the mapped IPv4 nexthop in BGP table needs to be translated to native IPv4 address when building the MPLS forwarding table when VPNv6 prefixes exchanged over IPv4 BGP session , but I need further invesigation about this just to be sure.
I think the nexthop translation is the smaller task. If RouterOS based on at least Linux v5.2 then we have a chance to implement v6 routes with v4 nexthop. FRR faced this in the past already: https://github.com/FRRouting/frr/issues/4661
Last comment goes to another thread where mention that Linux 5.2 has this function. Maybe…
you can already add static ipv6 routes with ipv4 gateways. But it was not possible to set it with routing filters, let me check now.
I tried adding a static IPv6 route and the results I got are as follows:
  • With the IPv4 gateway it was not possible (“invalid or unexpected argument base” message).
  • with IPv4 mapped to IPv6 gateway (in the format ::ffff:a.b.c.d) it was possible, however the route never became active.
[user@R1] > /ipv6/route/add dst-address=2803:c400::/32 gateway=::ffff:10.1.1.84
[user@R1] > routing/route/print where afi =ip6
Flags: U - UNREACHABLE, A - ACTIVE; c - CONNECT, s - STATIC, b - BGP, y - BGP-MPLS-VPN; H - HW-OFFLOADED
Columns: DST-ADDRESS, GATEWAY, AFI, DISTANCE, SCOPE, TARGET-SCOPE, IMMEDIATE-GW
    DST-ADDRESS                  GATEWAY                          AFI  DISTANCE  SCOPE  TARGET-SCOPE  IMMEDIATE-GW
UsH 2803:c400::/32               ::ffff:10.1.1.84                 ip6         1     30            10
As mrz said mapped IPv6 address is not valid IPv6 address. It should work if you configure vpnv6 on IPv6 BGP peer and configure LDPv6 and IGP ipv6 address-family.
If I understood correctly, here @mrz says that it is possible to add IPv6 routes with an IPv4 gateway.
sorry, but unfortunately no, you can add ipv4 route with ipv6 gateway, not the other way around.
FTR: It should, but it doesn’t. I tried IS-IS IPv6 over GRE, but nexthops doesn’t work. I switched back to OSPFv2+v3, it works, LDPv4+v6 works, but if I activate VPNv6 on our routers’s BGP connections, it eats up all router’s CPU and VPNv6 prefixes flapping.
Edit: IS-IS IPv6 LL fix is not in 7.15.1 but in 7.16beta1
Will that feature be present in the future? or is there a linux kernel limitation that makes it impossible to implement?
It depends on is it supported in the current kernel and if not how hard to implement it without other things falls apart. Without this option we need dual stack IGP and LDP to use both VPNv4 and VPNv6.
EDIT: and if I’m right it depends on how hard to implement this in RIB and FIB levels.
Would be awesome if we could get VPNv6 working via IPv4 MPLS LDP transport. That’s what many third party devices like H3C/HPE and Cisco support already.
I think they are adding it as a feature because it can be seen as an AFI on the CLI only
Proof for VPNv6 support:
https://help.mikrotik.com/docs/display/ROS/Routing+Protocol+Overview
