Now, no port option.
/interface l2tp-server server set enabled=yes
/interface l2tp-client add name=l2tp connect-to=10.1.1.1 user=1111 password=pwd
Please add port option, thank you! thank you! thank you!
/interface l2tp-server server set enabled=yes port=8443
/interface l2tp-client add name=l2tp connect-to=10.1.1.1 user=1111 password=pwd port=8443
There are many L2TP clients that need to be configured for connections.
Using dst-nat to change ports incurs extra CPU overhead and increases maintenance complexity.
But with L2TP port option, everything becomes easy!
Requesting MikroTik developers to add L2TP port option.
Thanks!Thanks!Thanks!
