Please,
can we have additional fields in /system identity to be able to describe the placement of the device?
These fields should be seen by SNMP also.
Thank you for your consideration.
Please,
you mean like this?
[bat@hgw] > sys identity print
[bat@hgw] > snmp print
enabled: yes
contact: bat
-> location: rack in the garage
engine-id:
i guess we’re pretty fine on the SNMP side:
crowley:~ bat$ snmpwalk -v 2c -c public router system
SNMPv2-MIB::sysDescr.0 = STRING: RouterOS RB2011UAS-2HnD
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.14988.1
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (144744500) 16 days, 18:04:05.00
SNMPv2-MIB::sysContact.0 = STRING: bat
SNMPv2-MIB::sysName.0 = STRING: hgw
SNMPv2-MIB::sysLocation.0 = STRING: rack in the garage
SNMPv2-MIB::sysServices.0 = INTEGER: 78
I mean exactly like this.
I just was not looking for it in SNMP… thanks.
