I would be interested to see such functionality in the address lists.
/ip firewall address-list add list=hosts address=192.168.0.0/16 wildcard=255.255.10-20.255Only networks will be third octet is in the range of 10-20
/ip firewall address-list add list=hosts address=192.168.0.0/16 wildcard=255.255.0.10third octet 0-255 and fourth octet 10
/ip firewall address-list add list=hosts address=192.168.0.0/16 wildcard=255.255.255.10,15,20,30-35fourth octet 10 or 15 or 20 or in range 30-35
/ip firewall address-list add list=GOOGLE address=AS15169Dynamic address list, address from AS number
[admin@MT-AP-KIRILL-ROOM] /ip firewall address-list> pr
Flags: X - disabled, D - dynamic
LIST ADDRESS CREATION-TIME TIMEOUT
0 GOOGLE AS15169 apr/06/2019 01:07:35
1 D ;;; AS15169
GOOGLE 103.21.184.0/22 apr/06/2019 01:27:57
2 D ;;; AS15169
GOOGLE 103.227.68.0/22 apr/06/2019 01:27:57
3 D ;;; AS15169
GOOGLE 103.240.192.0/22 apr/06/2019 01:27:57
/ip firewall address-list add list=mysite.com address=*.mysite.comwildcard or asterisk in all sub domain.
I know that you cannot get a list of sub domains, but if the router is a DNS server, it can find all such domains that are in the cache.
Splitting into ipv4 and ipv6 is needed due to the strange way RouterOS deals with IPv6.
Now this will turn them into .rsc files ready to import:
(echo "/ip firewall address-list {"; for prefix in $(whois -h whois.radb.net -- '-i origin AS15169' | grep ^route: | awk '{print $2}'| sort -u); do echo "add list=goog address=$prefix timeout=1d"; done; echo "}") > goog4.rsc
(echo "/ipv6 firewall address-list {"; for prefix in $(whois -h whois.radb.net -- '-i origin AS15169' | grep ^route6: | awk '{print $2}'| sort -u); do echo "add list=goog address=$prefix timeout=1d"; done; echo "}") >goog6.rsc
$ ls -l goog*
-rw-r--r-- 1 user user 345227 apr 7 08:25 goog4.rsc
-rw-r--r-- 1 user user 11439 apr 7 08:24 goog6.rsc
$ wc -l goog*.rsc
7146 goog4.rsc
225 goog6.rsc
7371 total
$ scp goog6.rsc 192.168.88.1:
$ ssh 192.168.88.1 "/import goog6.rsc"
$ ssh 192.168.88.1 "/ipv6 firewall address-list print where list=goog"
# LIST ADDRESS
0 D goo 2001:1900:2292::/48
1 D goo 2001:4860::/32
2 D goo 2401:fa00::/32
3 D goo 2401:fa00::/42
4 D goo 2401:fa00:4::/48
5 D goo 2404:6800::/32
6 D goo 2404:6800:4001::/48
Note that I only tested the ipv6 one, it is way smaller. Also, I put a timeout so that the lists will go on RAM.
Note also that the IPv6 list will need deduplication. It contains separate sub-prefixes of a given prefix as can be seen in my example. For instance it contains 2401:fa00::/32, 2401:fa00::/42 and 2401:fa00:4::/48, all included in the first.
That’s awesome. It is a good start to making a script that could for example let Google or Facebook in a Walled Garden list or perhaps QoS rule or blocking. I wish I knew how to deduplicate it.
It would be great as an online script generator. I tested it and it seemed an effective way to block Facebook in my firewall.
When I tried ipv4 it was failing due to a duplicate, but changing sort → sort -u makes it load. I edited the post. Removing entries that fall "inside"other entries, though, is a non-trivial programming problem.
