DDWRT, Tomato and OpenWRT have a feature that you can enable on the access points called “Bluetooth coexistence”.
The available options are: Disable, Enable and Preemption
I could find very little information on this but essentially when it’s on it makes a huge difference
to connected wifi clients who also use Bluetooth. I can find no such feature in RouterOS.
Would it be possible to add this?
