Feature Request: Bulk Port Allocation for CGNAT
Due to the issues in v6.x that prevents CCR equipment to be used in medium size border operations I have seen a growing number of ISPs using CCRs, specially 1036 and 1072 as CGNAT equipment and it has been working fairly well and with good performance as long the NAT rules are currently created.
However CGNAT configuration with these equipment only work with Port Fixed model which limits the usage for many environments and one thing that lacks for larger environments is CGNAT with Bulk Port Allocation which is the best model of CGNAT that gives both flexibility and very reduced logging to ISPs plus contributes a lot for greater IPv4 saving, a lot more than when used with Port Fixed.
Therefore if you can please add to a short term feature request to be implemented Bulk Port Allocation for CGNAT is something very positive, mainly with the recent release of CCR-2216 would become a excellent fit for this type of usage.
To find out more about a good Bulk Port Allocation implementation look at DANOS Project (https://www.danosproject.org/) which is working very well for several ISPs that are using it. Its simple logging format allows ISPs to comply with law enforcement easily.
I second that.
In fact, as a CGNAT I consider Mikrotik boxes excellent for. Especially when we replace them with other brands that deliver better performance on BGP functions eg.
With BPA feature, Mikrotik boxes would become competitive against manufacturers that have this functionality built in.
Excelent idea! The lack of IPv4 in the world makes two needs grow:
  • IPv6.
  • CGNAT.
    Speaking of CGNAT, the more savings in IPv4 resources, the better it will be for the operator. The Bulk Port Allocation model brings better management of these resources.
    Another detail that would increase sales for Mikrotik and put alternatives to expensive products on the market with the A10 (https://www.a10networks.com/products/thunder-cgn/) and F5 (https://www.f5.com /services/resources/use-cases/carrier-grade-nat-for-service-providers).
+1, I am already using CCRs for NAT but this would be awesome and simplify configuration greatly.
+1 for this
+1
and support for proper logging, off course
Re: … logging …
For CGN NAT , use NAT444 ( not the simple standard NAT44 ).
With 8 Live IPs , you can Nat an entire /21 CGN network and not need to log anything.
In my CGN networks , I NAT each CGN IP to 250 ports on a Live IP address.
There is no need to log your NAT translations.
When I get one of those copyright notices , they always indicate the IP address and the port. You just scan your static CGN NAT444 NAT tables for the Live IP address and port range you assigned to each of your CGN customers. It takes seconds and you don’t need a syslog server with billions of syslog-ed nat translations.
I have a dozen /21 CGN networks , it works fast on my Mikrotik CHR.
The down-side is need to run a script to create the thousands and thousands of lines of NAT code that goes into your Mikrotik. But after that head-ache , your done.
North Idaho Tom Jones
how much lines of NAT configuration you end up with for each /21 CGN ?
re: … how much lines of NAT configuration you end up with for each /21 CGN ? …
to NAT444 a /21 CGN block to 8 live IP address where each CGN IP address is assigned 250 ports from a live IP address
I use 6,335 lines of code in my CHR NAT router per /21 CGN network block.
In my network , I have two CHR routers that are each NAT444 NATting about six /21 CGN networks.
So , do the math ; 12 times 6,335 = 76-thousand 20 lines of NAT444 configuration lines of code.
What really surprised me is when I went from a single NAT44 ( normal NAT ) to my NAT444 configuration , my CGN networks actually got a little faster - go figure
Note - I have 10-gig interfaces on my CHRs. Some of my customers are on Fiber ( still NAT444 ) , and those customers can each hit and hold 1-Gig through the NAT444 router.
Thanks You for your reply
One think I would like to add about NAT444 ; When I was using the normal standard NAT44 , I would sometimes get some complaints for some customers that some thinks were not working ( nat related ). The moment I went to the more complex NAT444 , all of those complaints went away.
+1 for this feature
Sorry for posting in wrong thread.
But after reading this, i am totally confused between nat44 and nat444
I use nat like this :
add chain=srcnat src-address=172.18.23.0-172.18.23.255 action=jump jump-target=“CGNAT-0”
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.0/29 to-addresses=103.0.0.40/29 to-ports=1025-3041
add action=netmap chain=CGNAT-0 src-address=172.18.23.0/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.8/29 to-addresses=103.0.0.40/29 to-ports=3042-5057
add action=netmap chain=CGNAT-0 src-address=172.18.23.8/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.16/29 to-addresses=103.0.0.40/29 to-ports=5058-7073
add action=netmap chain=CGNAT-0 src-address=172.18.23.16/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.24/29 to-addresses=103.0.0.40/29 to-ports=7074-9089
add action=netmap chain=CGNAT-0 src-address=172.18.23.24/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.32/29 to-addresses=103.0.0.40/29 to-ports=9090-11105
add action=netmap chain=CGNAT-0 src-address=172.18.23.32/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.40/29 to-addresses=103.0.0.40/29 to-ports=11106-13121
add action=netmap chain=CGNAT-0 src-address=172.18.23.40/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.48/29 to-addresses=103.0.0.40/29 to-ports=13122-15137
add action=netmap chain=CGNAT-0 src-address=172.18.23.48/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.56/29 to-addresses=103.0.0.40/29 to-ports=15138-17153
add action=netmap chain=CGNAT-0 src-address=172.18.23.56/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.64/29 to-addresses=103.0.0.40/29 to-ports=17154-19169
add action=netmap chain=CGNAT-0 src-address=172.18.23.64/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.72/29 to-addresses=103.0.0.40/29 to-ports=19170-21185
add action=netmap chain=CGNAT-0 src-address=172.18.23.72/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.80/29 to-addresses=103.0.0.40/29 to-ports=21186-23201
add action=netmap chain=CGNAT-0 src-address=172.18.23.80/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.88/29 to-addresses=103.0.0.40/29 to-ports=23202-25217
add action=netmap chain=CGNAT-0 src-address=172.18.23.88/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.96/29 to-addresses=103.0.0.40/29 to-ports=25218-27233
add action=netmap chain=CGNAT-0 src-address=172.18.23.96/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.104/29 to-addresses=103.0.0.40/29 to-ports=27234-29249
add action=netmap chain=CGNAT-0 src-address=172.18.23.104/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.112/29 to-addresses=103.0.0.40/29 to-ports=29250-31265
add action=netmap chain=CGNAT-0 src-address=172.18.23.112/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.120/29 to-addresses=103.0.0.40/29 to-ports=31266-33281
add action=netmap chain=CGNAT-0 src-address=172.18.23.120/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.128/29 to-addresses=103.0.0.40/29 to-ports=33282-35297
add action=netmap chain=CGNAT-0 src-address=172.18.23.128/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.136/29 to-addresses=103.0.0.40/29 to-ports=35298-37313
add action=netmap chain=CGNAT-0 src-address=172.18.23.136/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.144/29 to-addresses=103.0.0.40/29 to-ports=37314-39329
add action=netmap chain=CGNAT-0 src-address=172.18.23.144/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.152/29 to-addresses=103.0.0.40/29 to-ports=39330-41345
add action=netmap chain=CGNAT-0 src-address=172.18.23.152/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.160/29 to-addresses=103.0.0.40/29 to-ports=41346-43361
add action=netmap chain=CGNAT-0 src-address=172.18.23.160/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.168/29 to-addresses=103.0.0.40/29 to-ports=43362-45377
add action=netmap chain=CGNAT-0 src-address=172.18.23.168/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.176/29 to-addresses=103.0.0.40/29 to-ports=45378-47393
add action=netmap chain=CGNAT-0 src-address=172.18.23.176/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.184/29 to-addresses=103.0.0.40/29 to-ports=47394-49409
add action=netmap chain=CGNAT-0 src-address=172.18.23.184/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.192/29 to-addresses=103.0.0.40/29 to-ports=49410-51425
add action=netmap chain=CGNAT-0 src-address=172.18.23.192/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.200/29 to-addresses=103.0.0.40/29 to-ports=51426-53441
add action=netmap chain=CGNAT-0 src-address=172.18.23.200/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.208/29 to-addresses=103.0.0.40/29 to-ports=53442-55457
add action=netmap chain=CGNAT-0 src-address=172.18.23.208/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.216/29 to-addresses=103.0.0.40/29 to-ports=55458-57473
add action=netmap chain=CGNAT-0 src-address=172.18.23.216/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.224/29 to-addresses=103.0.0.40/29 to-ports=57474-59489
add action=netmap chain=CGNAT-0 src-address=172.18.23.224/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.232/29 to-addresses=103.0.0.40/29 to-ports=59490-61505
add action=netmap chain=CGNAT-0 src-address=172.18.23.232/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.240/29 to-addresses=103.0.0.40/29 to-ports=61506-63521
add action=netmap chain=CGNAT-0 src-address=172.18.23.240/29 to-addresses=103.0.0.40/29
add action=netmap chain=CGNAT-0 protocol=tcp src-address=172.18.23.248/29 to-addresses=103.0.0.40/29 to-ports=63522-65535
add action=netmap chain=CGNAT-0 src-address=172.18.23.248/29 to-addresses=103.0.0.40/29
Is this nat44 or nat444 ?
How to identify them ?
** Would somebody else experienced with NAT444 please check my correctness in this post.
Here is an example of a NAT444 configuration.
Lets say you have a CGN block ip IP address to your customers which is 100.64.0.0/24
Lets also say you have a single Live IP address 192.0.254.0/30
Where your configuration is this:
Your Updream Internet provider IP address ( facing you ) is 192.0.254.1/30
The WAN interface on your router facing your your Internet provider is 192.0.254.2/30 ( Your default gateway is 192.0.254.1 ).
Your LAN to your customers is 100.64.0.1/24
  • You use 100.64.0.16/28 - through - 100.64.0.240/28 for your LAN connections to your customers.
    Here is one possible NAT 444 configuration below where each customer has 250 ports in your NAT444 configuration.
    With a NAT444 configuration ( such as below ), you can quickly find out what customer is using what range of ports.
    This help you track down a customer when you get one of those copyright notices ( which contain offender IP address and port # ).
Note: I left out the first part --> 100.64.0.0/28 so that you can use this part of the IP block for anything special you may want to do.
If you hade a 2'nd routed Live IP address for your NAT444 router , then you could use all of the NAT444 configuration below by simply removing the # at the start of all lines below.
add action=jump chain=srcnat jump-target=NAT444 src-address=100.64.0.0/24
add action=jump chain=NAT444 jump-target=NAT444-0 src-address=100.64.0.0/28
add action=jump chain=NAT444 jump-target=NAT444-1 src-address=100.64.0.16/28
add action=jump chain=NAT444 jump-target=NAT444-2 src-address=100.64.0.32/28
add action=jump chain=NAT444 jump-target=NAT444-3 src-address=100.64.0.48/28
add action=jump chain=NAT444 jump-target=NAT444-4 src-address=100.64.0.64/28
add action=jump chain=NAT444 jump-target=NAT444-5 src-address=100.64.0.80/28
add action=jump chain=NAT444 jump-target=NAT444-6 src-address=100.64.0.96/28
add action=jump chain=NAT444 jump-target=NAT444-7 src-address=100.64.0.112/28
add action=jump chain=NAT444 jump-target=NAT444-8 src-address=100.64.0.128/28
add action=jump chain=NAT444 jump-target=NAT444-9 src-address=100.64.0.144/28
add action=jump chain=NAT444 jump-target=NAT444-10 src-address=100.64.0.160/28
add action=jump chain=NAT444 jump-target=NAT444-11 src-address=100.64.0.176/28
add action=jump chain=NAT444 jump-target=NAT444-12 src-address=100.64.0.192/28
add action=jump chain=NAT444 jump-target=NAT444-13 src-address=100.64.0.208/28
add action=jump chain=NAT444 jump-target=NAT444-14 src-address=100.64.0.224/28
add action=jump chain=NAT444 jump-target=NAT444-15 src-address=100.64.0.240/28
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.0 to-# addresses=192.0.254.2 to-ports=1000-1249
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.0 to-# addresses=192.0.254.2 to-ports=1000-1249
add action=src-nat chain=NAT444-0 src-# address=100.64.0.0 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.1 to-# addresses=192.0.254.2 to-ports=1250-1499
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.1 to-# addresses=192.0.254.2 to-ports=1250-1499
add action=src-nat chain=NAT444-0 src-# address=100.64.0.1 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.2 to-# addresses=192.0.254.2 to-ports=1500-1749
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.2 to-# addresses=192.0.254.2 to-ports=1500-1749
add action=src-nat chain=NAT444-0 src-# address=100.64.0.2 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.3 to-# addresses=192.0.254.2 to-ports=1750-1999
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.3 to-# addresses=192.0.254.2 to-ports=1750-1999
add action=src-nat chain=NAT444-0 src-# address=100.64.0.3 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.4 to-# addresses=192.0.254.2 to-ports=2000-2249
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.4 to-# addresses=192.0.254.2 to-ports=2000-2249
add action=src-nat chain=NAT444-0 src-# address=100.64.0.4 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.5 to-# addresses=192.0.254.2 to-ports=2250-2499
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.5 to-# addresses=192.0.254.2 to-ports=2250-2499
add action=src-nat chain=NAT444-0 src-# address=100.64.0.5 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.6 to-# addresses=192.0.254.2 to-ports=2500-2749
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.6 to-# addresses=192.0.254.2 to-ports=2500-2749
add action=src-nat chain=NAT444-0 src-# address=100.64.0.6 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.7 to-# addresses=192.0.254.2 to-ports=2750-2999
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.7 to-# addresses=192.0.254.2 to-ports=2750-2999
add action=src-nat chain=NAT444-0 src-# address=100.64.0.7 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.8 to-# addresses=192.0.254.2 to-ports=3000-3249
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.8 to-# addresses=192.0.254.2 to-ports=3000-3249
add action=src-nat chain=NAT444-0 src-# address=100.64.0.8 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.9 to-# addresses=192.0.254.2 to-ports=3250-3499
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.9 to-# addresses=192.0.254.2 to-ports=3250-3499
add action=src-nat chain=NAT444-0 src-# address=100.64.0.9 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.10 to-# addresses=192.0.254.2 to-ports=3500-3749
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.10 to-# addresses=192.0.254.2 to-ports=3500-3749
add action=src-nat chain=NAT444-0 src-# address=100.64.0.10 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.11 to-# addresses=192.0.254.2 to-ports=3750-3999
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.11 to-# addresses=192.0.254.2 to-ports=3750-3999
add action=src-nat chain=NAT444-0 src-# address=100.64.0.11 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.12 to-# addresses=192.0.254.2 to-ports=4000-4249
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.12 to-# addresses=192.0.254.2 to-ports=4000-4249
add action=src-nat chain=NAT444-0 src-# address=100.64.0.12 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.13 to-# addresses=192.0.254.2 to-ports=4250-4499
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.13 to-# addresses=192.0.254.2 to-ports=4250-4499
add action=src-nat chain=NAT444-0 src-# address=100.64.0.13 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.14 to-# addresses=192.0.254.2 to-ports=4500-4749
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.14 to-# addresses=192.0.254.2 to-ports=4500-4749
add action=src-nat chain=NAT444-0 src-# address=100.64.0.14 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-0 protocol=tcp src-# address=100.64.0.15 to-# addresses=192.0.254.2 to-ports=4750-4999
add action=src-nat chain=NAT444-0 protocol=udp src-# address=100.64.0.15 to-# addresses=192.0.254.2 to-ports=4750-4999
add action=src-nat chain=NAT444-0 src-# address=100.64.0.15 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-# address=100.64.0.16 to-# addresses=192.0.254.2 to-ports=5000-5249
add action=src-nat chain=NAT444-1 protocol=udp src-# address=100.64.0.16 to-# addresses=192.0.254.2 to-ports=5000-5249
add action=src-nat chain=NAT444-1 src-# address=100.64.0.16 to-# addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.17 to-addresses=192.0.254.2 to-ports=5250-5499
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.17 to-addresses=192.0.254.2 to-ports=5250-5499
add action=src-nat chain=NAT444-1 src-address=100.64.0.17 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.18 to-addresses=192.0.254.2 to-ports=5500-5749
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.18 to-addresses=192.0.254.2 to-ports=5500-5749
add action=src-nat chain=NAT444-1 src-address=100.64.0.18 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.19 to-addresses=192.0.254.2 to-ports=5750-5999
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.19 to-addresses=192.0.254.2 to-ports=5750-5999
add action=src-nat chain=NAT444-1 src-address=100.64.0.19 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.20 to-addresses=192.0.254.2 to-ports=6000-6249
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.20 to-addresses=192.0.254.2 to-ports=6000-6249
add action=src-nat chain=NAT444-1 src-address=100.64.0.20 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.21 to-addresses=192.0.254.2 to-ports=6250-6499
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.21 to-addresses=192.0.254.2 to-ports=6250-6499
add action=src-nat chain=NAT444-1 src-address=100.64.0.21 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.22 to-addresses=192.0.254.2 to-ports=6500-6749
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.22 to-addresses=192.0.254.2 to-ports=6500-6749
add action=src-nat chain=NAT444-1 src-address=100.64.0.22 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.23 to-addresses=192.0.254.2 to-ports=6750-6999
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.23 to-addresses=192.0.254.2 to-ports=6750-6999
add action=src-nat chain=NAT444-1 src-address=100.64.0.23 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.24 to-addresses=192.0.254.2 to-ports=7000-7249
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.24 to-addresses=192.0.254.2 to-ports=7000-7249
add action=src-nat chain=NAT444-1 src-address=100.64.0.24 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.25 to-addresses=192.0.254.2 to-ports=7250-7499
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.25 to-addresses=192.0.254.2 to-ports=7250-7499
add action=src-nat chain=NAT444-1 src-address=100.64.0.25 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.26 to-addresses=192.0.254.2 to-ports=7500-7749
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.26 to-addresses=192.0.254.2 to-ports=7500-7749
add action=src-nat chain=NAT444-1 src-address=100.64.0.26 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.27 to-addresses=192.0.254.2 to-ports=7750-7999
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.27 to-addresses=192.0.254.2 to-ports=7750-7999
add action=src-nat chain=NAT444-1 src-address=100.64.0.27 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.28 to-addresses=192.0.254.2 to-ports=8000-8249
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.28 to-addresses=192.0.254.2 to-ports=8000-8249
add action=src-nat chain=NAT444-1 src-address=100.64.0.28 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.29 to-addresses=192.0.254.2 to-ports=8250-8499
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.29 to-addresses=192.0.254.2 to-ports=8250-8499
add action=src-nat chain=NAT444-1 src-address=100.64.0.29 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.30 to-addresses=192.0.254.2 to-ports=8500-8749
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.30 to-addresses=192.0.254.2 to-ports=8500-8749
add action=src-nat chain=NAT444-1 src-address=100.64.0.30 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-1 protocol=tcp src-address=100.64.0.31 to-addresses=192.0.254.2 to-ports=8750-8999
add action=src-nat chain=NAT444-1 protocol=udp src-address=100.64.0.31 to-addresses=192.0.254.2 to-ports=8750-8999
add action=src-nat chain=NAT444-1 src-address=100.64.0.31 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.32 to-addresses=192.0.254.2 to-ports=9000-9249
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.32 to-addresses=192.0.254.2 to-ports=9000-9249
add action=src-nat chain=NAT444-2 src-address=100.64.0.32 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.33 to-addresses=192.0.254.2 to-ports=9250-9499
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.33 to-addresses=192.0.254.2 to-ports=9250-9499
add action=src-nat chain=NAT444-2 src-address=100.64.0.33 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.34 to-addresses=192.0.254.2 to-ports=9500-9749
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.34 to-addresses=192.0.254.2 to-ports=9500-9749
add action=src-nat chain=NAT444-2 src-address=100.64.0.34 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.35 to-addresses=192.0.254.2 to-ports=9750-9999
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.35 to-addresses=192.0.254.2 to-ports=9750-9999
add action=src-nat chain=NAT444-2 src-address=100.64.0.35 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.36 to-addresses=192.0.254.2 to-ports=10000-10249
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.36 to-addresses=192.0.254.2 to-ports=10000-10249
add action=src-nat chain=NAT444-2 src-address=100.64.0.36 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.37 to-addresses=192.0.254.2 to-ports=10250-10499
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.37 to-addresses=192.0.254.2 to-ports=10250-10499
add action=src-nat chain=NAT444-2 src-address=100.64.0.37 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.38 to-addresses=192.0.254.2 to-ports=10500-10749
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.38 to-addresses=192.0.254.2 to-ports=10500-10749
add action=src-nat chain=NAT444-2 src-address=100.64.0.38 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.39 to-addresses=192.0.254.2 to-ports=10750-10999
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.39 to-addresses=192.0.254.2 to-ports=10750-10999
add action=src-nat chain=NAT444-2 src-address=100.64.0.39 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.40 to-addresses=192.0.254.2 to-ports=11000-11249
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.40 to-addresses=192.0.254.2 to-ports=11000-11249
add action=src-nat chain=NAT444-2 src-address=100.64.0.40 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.41 to-addresses=192.0.254.2 to-ports=11250-11499
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.41 to-addresses=192.0.254.2 to-ports=11250-11499
add action=src-nat chain=NAT444-2 src-address=100.64.0.41 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.42 to-addresses=192.0.254.2 to-ports=11500-11749
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.42 to-addresses=192.0.254.2 to-ports=11500-11749
add action=src-nat chain=NAT444-2 src-address=100.64.0.42 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.43 to-addresses=192.0.254.2 to-ports=11750-11999
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.43 to-addresses=192.0.254.2 to-ports=11750-11999
add action=src-nat chain=NAT444-2 src-address=100.64.0.43 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.44 to-addresses=192.0.254.2 to-ports=12000-12249
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.44 to-addresses=192.0.254.2 to-ports=12000-12249
add action=src-nat chain=NAT444-2 src-address=100.64.0.44 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.45 to-addresses=192.0.254.2 to-ports=12250-12499
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.45 to-addresses=192.0.254.2 to-ports=12250-12499
add action=src-nat chain=NAT444-2 src-address=100.64.0.45 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.46 to-addresses=192.0.254.2 to-ports=12500-12749
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.46 to-addresses=192.0.254.2 to-ports=12500-12749
add action=src-nat chain=NAT444-2 src-address=100.64.0.46 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-2 protocol=tcp src-address=100.64.0.47 to-addresses=192.0.254.2 to-ports=12750-12999
add action=src-nat chain=NAT444-2 protocol=udp src-address=100.64.0.47 to-addresses=192.0.254.2 to-ports=12750-12999
add action=src-nat chain=NAT444-2 src-address=100.64.0.47 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.48 to-addresses=192.0.254.2 to-ports=13000-13249
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.48 to-addresses=192.0.254.2 to-ports=13000-13249
add action=src-nat chain=NAT444-3 src-address=100.64.0.48 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.49 to-addresses=192.0.254.2 to-ports=13250-13499
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.49 to-addresses=192.0.254.2 to-ports=13250-13499
add action=src-nat chain=NAT444-3 src-address=100.64.0.49 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.50 to-addresses=192.0.254.2 to-ports=13500-13749
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.50 to-addresses=192.0.254.2 to-ports=13500-13749
add action=src-nat chain=NAT444-3 src-address=100.64.0.50 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.51 to-addresses=192.0.254.2 to-ports=13750-13999
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.51 to-addresses=192.0.254.2 to-ports=13750-13999
add action=src-nat chain=NAT444-3 src-address=100.64.0.51 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.52 to-addresses=192.0.254.2 to-ports=14000-14249
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.52 to-addresses=192.0.254.2 to-ports=14000-14249
add action=src-nat chain=NAT444-3 src-address=100.64.0.52 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.53 to-addresses=192.0.254.2 to-ports=14250-14499
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.53 to-addresses=192.0.254.2 to-ports=14250-14499
add action=src-nat chain=NAT444-3 src-address=100.64.0.53 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.54 to-addresses=192.0.254.2 to-ports=14500-14749
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.54 to-addresses=192.0.254.2 to-ports=14500-14749
add action=src-nat chain=NAT444-3 src-address=100.64.0.54 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.55 to-addresses=192.0.254.2 to-ports=14750-14999
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.55 to-addresses=192.0.254.2 to-ports=14750-14999
add action=src-nat chain=NAT444-3 src-address=100.64.0.55 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.56 to-addresses=192.0.254.2 to-ports=15000-15249
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.56 to-addresses=192.0.254.2 to-ports=15000-15249
add action=src-nat chain=NAT444-3 src-address=100.64.0.56 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.57 to-addresses=192.0.254.2 to-ports=15250-15499
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.57 to-addresses=192.0.254.2 to-ports=15250-15499
add action=src-nat chain=NAT444-3 src-address=100.64.0.57 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.58 to-addresses=192.0.254.2 to-ports=15500-15749
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.58 to-addresses=192.0.254.2 to-ports=15500-15749
add action=src-nat chain=NAT444-3 src-address=100.64.0.58 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.59 to-addresses=192.0.254.2 to-ports=15750-15999
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.59 to-addresses=192.0.254.2 to-ports=15750-15999
add action=src-nat chain=NAT444-3 src-address=100.64.0.59 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.60 to-addresses=192.0.254.2 to-ports=16000-16249
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.60 to-addresses=192.0.254.2 to-ports=16000-16249
add action=src-nat chain=NAT444-3 src-address=100.64.0.60 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.61 to-addresses=192.0.254.2 to-ports=16250-16499
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.61 to-addresses=192.0.254.2 to-ports=16250-16499
add action=src-nat chain=NAT444-3 src-address=100.64.0.61 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.62 to-addresses=192.0.254.2 to-ports=16500-16749
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.62 to-addresses=192.0.254.2 to-ports=16500-16749
add action=src-nat chain=NAT444-3 src-address=100.64.0.62 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-3 protocol=tcp src-address=100.64.0.63 to-addresses=192.0.254.2 to-ports=16750-16999
add action=src-nat chain=NAT444-3 protocol=udp src-address=100.64.0.63 to-addresses=192.0.254.2 to-ports=16750-16999
add action=src-nat chain=NAT444-3 src-address=100.64.0.63 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.64 to-addresses=192.0.254.2 to-ports=17000-17249
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.64 to-addresses=192.0.254.2 to-ports=17000-17249
add action=src-nat chain=NAT444-4 src-address=100.64.0.64 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.65 to-addresses=192.0.254.2 to-ports=17250-17499
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.65 to-addresses=192.0.254.2 to-ports=17250-17499
add action=src-nat chain=NAT444-4 src-address=100.64.0.65 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.66 to-addresses=192.0.254.2 to-ports=17500-17749
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.66 to-addresses=192.0.254.2 to-ports=17500-17749
add action=src-nat chain=NAT444-4 src-address=100.64.0.66 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.67 to-addresses=192.0.254.2 to-ports=17750-17999
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.67 to-addresses=192.0.254.2 to-ports=17750-17999
add action=src-nat chain=NAT444-4 src-address=100.64.0.67 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.68 to-addresses=192.0.254.2 to-ports=18000-18249
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.68 to-addresses=192.0.254.2 to-ports=18000-18249
add action=src-nat chain=NAT444-4 src-address=100.64.0.68 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.69 to-addresses=192.0.254.2 to-ports=18250-18499
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.69 to-addresses=192.0.254.2 to-ports=18250-18499
add action=src-nat chain=NAT444-4 src-address=100.64.0.69 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.70 to-addresses=192.0.254.2 to-ports=18500-18749
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.70 to-addresses=192.0.254.2 to-ports=18500-18749
add action=src-nat chain=NAT444-4 src-address=100.64.0.70 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.71 to-addresses=192.0.254.2 to-ports=18750-18999
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.71 to-addresses=192.0.254.2 to-ports=18750-18999
add action=src-nat chain=NAT444-4 src-address=100.64.0.71 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.72 to-addresses=192.0.254.2 to-ports=19000-19249
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.72 to-addresses=192.0.254.2 to-ports=19000-19249
add action=src-nat chain=NAT444-4 src-address=100.64.0.72 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.73 to-addresses=192.0.254.2 to-ports=19250-19499
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.73 to-addresses=192.0.254.2 to-ports=19250-19499
add action=src-nat chain=NAT444-4 src-address=100.64.0.73 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.74 to-addresses=192.0.254.2 to-ports=19500-19749
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.74 to-addresses=192.0.254.2 to-ports=19500-19749
add action=src-nat chain=NAT444-4 src-address=100.64.0.74 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.75 to-addresses=192.0.254.2 to-ports=19750-19999
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.75 to-addresses=192.0.254.2 to-ports=19750-19999
add action=src-nat chain=NAT444-4 src-address=100.64.0.75 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.76 to-addresses=192.0.254.2 to-ports=20000-20249
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.76 to-addresses=192.0.254.2 to-ports=20000-20249
add action=src-nat chain=NAT444-4 src-address=100.64.0.76 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.77 to-addresses=192.0.254.2 to-ports=20250-20499
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.77 to-addresses=192.0.254.2 to-ports=20250-20499
add action=src-nat chain=NAT444-4 src-address=100.64.0.77 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.78 to-addresses=192.0.254.2 to-ports=20500-20749
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.78 to-addresses=192.0.254.2 to-ports=20500-20749
add action=src-nat chain=NAT444-4 src-address=100.64.0.78 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-4 protocol=tcp src-address=100.64.0.79 to-addresses=192.0.254.2 to-ports=20750-20999
add action=src-nat chain=NAT444-4 protocol=udp src-address=100.64.0.79 to-addresses=192.0.254.2 to-ports=20750-20999
add action=src-nat chain=NAT444-4 src-address=100.64.0.79 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.80 to-addresses=192.0.254.2 to-ports=21000-21249
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.80 to-addresses=192.0.254.2 to-ports=21000-21249
add action=src-nat chain=NAT444-5 src-address=100.64.0.80 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.81 to-addresses=192.0.254.2 to-ports=21250-21499
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.81 to-addresses=192.0.254.2 to-ports=21250-21499
add action=src-nat chain=NAT444-5 src-address=100.64.0.81 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.82 to-addresses=192.0.254.2 to-ports=21500-21749
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.82 to-addresses=192.0.254.2 to-ports=21500-21749
add action=src-nat chain=NAT444-5 src-address=100.64.0.82 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.83 to-addresses=192.0.254.2 to-ports=21750-21999
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.83 to-addresses=192.0.254.2 to-ports=21750-21999
add action=src-nat chain=NAT444-5 src-address=100.64.0.83 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.84 to-addresses=192.0.254.2 to-ports=22000-22249
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.84 to-addresses=192.0.254.2 to-ports=22000-22249
add action=src-nat chain=NAT444-5 src-address=100.64.0.84 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.85 to-addresses=192.0.254.2 to-ports=22250-22499
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.85 to-addresses=192.0.254.2 to-ports=22250-22499
add action=src-nat chain=NAT444-5 src-address=100.64.0.85 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.86 to-addresses=192.0.254.2 to-ports=22500-22749
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.86 to-addresses=192.0.254.2 to-ports=22500-22749
add action=src-nat chain=NAT444-5 src-address=100.64.0.86 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.87 to-addresses=192.0.254.2 to-ports=22750-22999
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.87 to-addresses=192.0.254.2 to-ports=22750-22999
add action=src-nat chain=NAT444-5 src-address=100.64.0.87 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.88 to-addresses=192.0.254.2 to-ports=23000-23249
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.88 to-addresses=192.0.254.2 to-ports=23000-23249
add action=src-nat chain=NAT444-5 src-address=100.64.0.88 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.89 to-addresses=192.0.254.2 to-ports=23250-23499
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.89 to-addresses=192.0.254.2 to-ports=23250-23499
add action=src-nat chain=NAT444-5 src-address=100.64.0.89 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.90 to-addresses=192.0.254.2 to-ports=23500-23749
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.90 to-addresses=192.0.254.2 to-ports=23500-23749
add action=src-nat chain=NAT444-5 src-address=100.64.0.90 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.91 to-addresses=192.0.254.2 to-ports=23750-23999
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.91 to-addresses=192.0.254.2 to-ports=23750-23999
add action=src-nat chain=NAT444-5 src-address=100.64.0.91 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.92 to-addresses=192.0.254.2 to-ports=24000-24249
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.92 to-addresses=192.0.254.2 to-ports=24000-24249
add action=src-nat chain=NAT444-5 src-address=100.64.0.92 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.93 to-addresses=192.0.254.2 to-ports=24250-24499
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.93 to-addresses=192.0.254.2 to-ports=24250-24499
add action=src-nat chain=NAT444-5 src-address=100.64.0.93 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.94 to-addresses=192.0.254.2 to-ports=24500-24749
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.94 to-addresses=192.0.254.2 to-ports=24500-24749
add action=src-nat chain=NAT444-5 src-address=100.64.0.94 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-5 protocol=tcp src-address=100.64.0.95 to-addresses=192.0.254.2 to-ports=24750-24999
add action=src-nat chain=NAT444-5 protocol=udp src-address=100.64.0.95 to-addresses=192.0.254.2 to-ports=24750-24999
add action=src-nat chain=NAT444-5 src-address=100.64.0.95 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.96 to-addresses=192.0.254.2 to-ports=25000-25249
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.96 to-addresses=192.0.254.2 to-ports=25000-25249
add action=src-nat chain=NAT444-6 src-address=100.64.0.96 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.97 to-addresses=192.0.254.2 to-ports=25250-25499
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.97 to-addresses=192.0.254.2 to-ports=25250-25499
add action=src-nat chain=NAT444-6 src-address=100.64.0.97 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.98 to-addresses=192.0.254.2 to-ports=25500-25749
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.98 to-addresses=192.0.254.2 to-ports=25500-25749
add action=src-nat chain=NAT444-6 src-address=100.64.0.98 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.99 to-addresses=192.0.254.2 to-ports=25750-25999
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.99 to-addresses=192.0.254.2 to-ports=25750-25999
add action=src-nat chain=NAT444-6 src-address=100.64.0.99 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.100 to-addresses=192.0.254.2 to-ports=26000-26249
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.100 to-addresses=192.0.254.2 to-ports=26000-26249
add action=src-nat chain=NAT444-6 src-address=100.64.0.100 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.101 to-addresses=192.0.254.2 to-ports=26250-26499
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.101 to-addresses=192.0.254.2 to-ports=26250-26499
add action=src-nat chain=NAT444-6 src-address=100.64.0.101 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.102 to-addresses=192.0.254.2 to-ports=26500-26749
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.102 to-addresses=192.0.254.2 to-ports=26500-26749
add action=src-nat chain=NAT444-6 src-address=100.64.0.102 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.103 to-addresses=192.0.254.2 to-ports=26750-26999
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.103 to-addresses=192.0.254.2 to-ports=26750-26999
add action=src-nat chain=NAT444-6 src-address=100.64.0.103 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.104 to-addresses=192.0.254.2 to-ports=27000-27249
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.104 to-addresses=192.0.254.2 to-ports=27000-27249
add action=src-nat chain=NAT444-6 src-address=100.64.0.104 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.105 to-addresses=192.0.254.2 to-ports=27250-27499
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.105 to-addresses=192.0.254.2 to-ports=27250-27499
add action=src-nat chain=NAT444-6 src-address=100.64.0.105 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.106 to-addresses=192.0.254.2 to-ports=27500-27749
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.106 to-addresses=192.0.254.2 to-ports=27500-27749
add action=src-nat chain=NAT444-6 src-address=100.64.0.106 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.107 to-addresses=192.0.254.2 to-ports=27750-27999
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.107 to-addresses=192.0.254.2 to-ports=27750-27999
add action=src-nat chain=NAT444-6 src-address=100.64.0.107 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.108 to-addresses=192.0.254.2 to-ports=28000-28249
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.108 to-addresses=192.0.254.2 to-ports=28000-28249
add action=src-nat chain=NAT444-6 src-address=100.64.0.108 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.109 to-addresses=192.0.254.2 to-ports=28250-28499
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.109 to-addresses=192.0.254.2 to-ports=28250-28499
add action=src-nat chain=NAT444-6 src-address=100.64.0.109 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.110 to-addresses=192.0.254.2 to-ports=28500-28749
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.110 to-addresses=192.0.254.2 to-ports=28500-28749
add action=src-nat chain=NAT444-6 src-address=100.64.0.110 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-6 protocol=tcp src-address=100.64.0.111 to-addresses=192.0.254.2 to-ports=28750-28999
add action=src-nat chain=NAT444-6 protocol=udp src-address=100.64.0.111 to-addresses=192.0.254.2 to-ports=28750-28999
add action=src-nat chain=NAT444-6 src-address=100.64.0.111 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.112 to-addresses=192.0.254.2 to-ports=29000-29249
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.112 to-addresses=192.0.254.2 to-ports=29000-29249
add action=src-nat chain=NAT444-7 src-address=100.64.0.112 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.113 to-addresses=192.0.254.2 to-ports=29250-29499
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.113 to-addresses=192.0.254.2 to-ports=29250-29499
add action=src-nat chain=NAT444-7 src-address=100.64.0.113 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.114 to-addresses=192.0.254.2 to-ports=29500-29749
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.114 to-addresses=192.0.254.2 to-ports=29500-29749
add action=src-nat chain=NAT444-7 src-address=100.64.0.114 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.115 to-addresses=192.0.254.2 to-ports=29750-29999
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.115 to-addresses=192.0.254.2 to-ports=29750-29999
add action=src-nat chain=NAT444-7 src-address=100.64.0.115 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.116 to-addresses=192.0.254.2 to-ports=30000-30249
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.116 to-addresses=192.0.254.2 to-ports=30000-30249
add action=src-nat chain=NAT444-7 src-address=100.64.0.116 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.117 to-addresses=192.0.254.2 to-ports=30250-30499
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.117 to-addresses=192.0.254.2 to-ports=30250-30499
add action=src-nat chain=NAT444-7 src-address=100.64.0.117 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.118 to-addresses=192.0.254.2 to-ports=30500-30749
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.118 to-addresses=192.0.254.2 to-ports=30500-30749
add action=src-nat chain=NAT444-7 src-address=100.64.0.118 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.119 to-addresses=192.0.254.2 to-ports=30750-30999
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.119 to-addresses=192.0.254.2 to-ports=30750-30999
add action=src-nat chain=NAT444-7 src-address=100.64.0.119 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.120 to-addresses=192.0.254.2 to-ports=31000-31249
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.120 to-addresses=192.0.254.2 to-ports=31000-31249
add action=src-nat chain=NAT444-7 src-address=100.64.0.120 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.121 to-addresses=192.0.254.2 to-ports=31250-31499
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.121 to-addresses=192.0.254.2 to-ports=31250-31499
add action=src-nat chain=NAT444-7 src-address=100.64.0.121 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.122 to-addresses=192.0.254.2 to-ports=31500-31749
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.122 to-addresses=192.0.254.2 to-ports=31500-31749
add action=src-nat chain=NAT444-7 src-address=100.64.0.122 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.123 to-addresses=192.0.254.2 to-ports=31750-31999
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.123 to-addresses=192.0.254.2 to-ports=31750-31999
add action=src-nat chain=NAT444-7 src-address=100.64.0.123 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.124 to-addresses=192.0.254.2 to-ports=32000-32249
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.124 to-addresses=192.0.254.2 to-ports=32000-32249
add action=src-nat chain=NAT444-7 src-address=100.64.0.124 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.125 to-addresses=192.0.254.2 to-ports=32250-32499
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.125 to-addresses=192.0.254.2 to-ports=32250-32499
add action=src-nat chain=NAT444-7 src-address=100.64.0.125 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.126 to-addresses=192.0.254.2 to-ports=32500-32749
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.126 to-addresses=192.0.254.2 to-ports=32500-32749
add action=src-nat chain=NAT444-7 src-address=100.64.0.126 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-7 protocol=tcp src-address=100.64.0.127 to-addresses=192.0.254.2 to-ports=32750-32999
add action=src-nat chain=NAT444-7 protocol=udp src-address=100.64.0.127 to-addresses=192.0.254.2 to-ports=32750-32999
add action=src-nat chain=NAT444-7 src-address=100.64.0.127 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.128 to-addresses=192.0.254.2 to-ports=33000-33249
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.128 to-addresses=192.0.254.2 to-ports=33000-33249
add action=src-nat chain=NAT444-8 src-address=100.64.0.128 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.129 to-addresses=192.0.254.2 to-ports=33250-33499
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.129 to-addresses=192.0.254.2 to-ports=33250-33499
add action=src-nat chain=NAT444-8 src-address=100.64.0.129 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.130 to-addresses=192.0.254.2 to-ports=33500-33749
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.130 to-addresses=192.0.254.2 to-ports=33500-33749
add action=src-nat chain=NAT444-8 src-address=100.64.0.130 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.131 to-addresses=192.0.254.2 to-ports=33750-33999
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.131 to-addresses=192.0.254.2 to-ports=33750-33999
add action=src-nat chain=NAT444-8 src-address=100.64.0.131 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.132 to-addresses=192.0.254.2 to-ports=34000-34249
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.132 to-addresses=192.0.254.2 to-ports=34000-34249
add action=src-nat chain=NAT444-8 src-address=100.64.0.132 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.133 to-addresses=192.0.254.2 to-ports=34250-34499
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.133 to-addresses=192.0.254.2 to-ports=34250-34499
add action=src-nat chain=NAT444-8 src-address=100.64.0.133 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.134 to-addresses=192.0.254.2 to-ports=34500-34749
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.134 to-addresses=192.0.254.2 to-ports=34500-34749
add action=src-nat chain=NAT444-8 src-address=100.64.0.134 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.135 to-addresses=192.0.254.2 to-ports=34750-34999
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.135 to-addresses=192.0.254.2 to-ports=34750-34999
add action=src-nat chain=NAT444-8 src-address=100.64.0.135 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.136 to-addresses=192.0.254.2 to-ports=35000-35249
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.136 to-addresses=192.0.254.2 to-ports=35000-35249
add action=src-nat chain=NAT444-8 src-address=100.64.0.136 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.137 to-addresses=192.0.254.2 to-ports=35250-35499
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.137 to-addresses=192.0.254.2 to-ports=35250-35499
add action=src-nat chain=NAT444-8 src-address=100.64.0.137 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.138 to-addresses=192.0.254.2 to-ports=35500-35749
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.138 to-addresses=192.0.254.2 to-ports=35500-35749
add action=src-nat chain=NAT444-8 src-address=100.64.0.138 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.139 to-addresses=192.0.254.2 to-ports=35750-35999
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.139 to-addresses=192.0.254.2 to-ports=35750-35999
add action=src-nat chain=NAT444-8 src-address=100.64.0.139 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.140 to-addresses=192.0.254.2 to-ports=36000-36249
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.140 to-addresses=192.0.254.2 to-ports=36000-36249
add action=src-nat chain=NAT444-8 src-address=100.64.0.140 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.141 to-addresses=192.0.254.2 to-ports=36250-36499
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.141 to-addresses=192.0.254.2 to-ports=36250-36499
add action=src-nat chain=NAT444-8 src-address=100.64.0.141 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.142 to-addresses=192.0.254.2 to-ports=36500-36749
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.142 to-addresses=192.0.254.2 to-ports=36500-36749
add action=src-nat chain=NAT444-8 src-address=100.64.0.142 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-8 protocol=tcp src-address=100.64.0.143 to-addresses=192.0.254.2 to-ports=36750-36999
add action=src-nat chain=NAT444-8 protocol=udp src-address=100.64.0.143 to-addresses=192.0.254.2 to-ports=36750-36999
add action=src-nat chain=NAT444-8 src-address=100.64.0.143 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.144 to-addresses=192.0.254.2 to-ports=37000-37249
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.144 to-addresses=192.0.254.2 to-ports=37000-37249
add action=src-nat chain=NAT444-9 src-address=100.64.0.144 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.145 to-addresses=192.0.254.2 to-ports=37250-37499
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.145 to-addresses=192.0.254.2 to-ports=37250-37499
add action=src-nat chain=NAT444-9 src-address=100.64.0.145 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.146 to-addresses=192.0.254.2 to-ports=37500-37749
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.146 to-addresses=192.0.254.2 to-ports=37500-37749
add action=src-nat chain=NAT444-9 src-address=100.64.0.146 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.147 to-addresses=192.0.254.2 to-ports=37750-37999
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.147 to-addresses=192.0.254.2 to-ports=37750-37999
add action=src-nat chain=NAT444-9 src-address=100.64.0.147 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.148 to-addresses=192.0.254.2 to-ports=38000-38249
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.148 to-addresses=192.0.254.2 to-ports=38000-38249
add action=src-nat chain=NAT444-9 src-address=100.64.0.148 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.149 to-addresses=192.0.254.2 to-ports=38250-38499
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.149 to-addresses=192.0.254.2 to-ports=38250-38499
add action=src-nat chain=NAT444-9 src-address=100.64.0.149 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.150 to-addresses=192.0.254.2 to-ports=38500-38749
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.150 to-addresses=192.0.254.2 to-ports=38500-38749
add action=src-nat chain=NAT444-9 src-address=100.64.0.150 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.151 to-addresses=192.0.254.2 to-ports=38750-38999
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.151 to-addresses=192.0.254.2 to-ports=38750-38999
add action=src-nat chain=NAT444-9 src-address=100.64.0.151 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.152 to-addresses=192.0.254.2 to-ports=39000-39249
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.152 to-addresses=192.0.254.2 to-ports=39000-39249
add action=src-nat chain=NAT444-9 src-address=100.64.0.152 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.153 to-addresses=192.0.254.2 to-ports=39250-39499
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.153 to-addresses=192.0.254.2 to-ports=39250-39499
add action=src-nat chain=NAT444-9 src-address=100.64.0.153 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.154 to-addresses=192.0.254.2 to-ports=39500-39749
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.154 to-addresses=192.0.254.2 to-ports=39500-39749
add action=src-nat chain=NAT444-9 src-address=100.64.0.154 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.155 to-addresses=192.0.254.2 to-ports=39750-39999
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.155 to-addresses=192.0.254.2 to-ports=39750-39999
add action=src-nat chain=NAT444-9 src-address=100.64.0.155 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.156 to-addresses=192.0.254.2 to-ports=40000-40249
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.156 to-addresses=192.0.254.2 to-ports=40000-40249
add action=src-nat chain=NAT444-9 src-address=100.64.0.156 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.157 to-addresses=192.0.254.2 to-ports=40250-40499
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.157 to-addresses=192.0.254.2 to-ports=40250-40499
add action=src-nat chain=NAT444-9 src-address=100.64.0.157 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.158 to-addresses=192.0.254.2 to-ports=40500-40749
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.158 to-addresses=192.0.254.2 to-ports=40500-40749
add action=src-nat chain=NAT444-9 src-address=100.64.0.158 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-9 protocol=tcp src-address=100.64.0.159 to-addresses=192.0.254.2 to-ports=40750-40999
add action=src-nat chain=NAT444-9 protocol=udp src-address=100.64.0.159 to-addresses=192.0.254.2 to-ports=40750-40999
add action=src-nat chain=NAT444-9 src-address=100.64.0.159 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.160 to-addresses=192.0.254.2 to-ports=41000-41249
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.160 to-addresses=192.0.254.2 to-ports=41000-41249
add action=src-nat chain=NAT444-10 src-address=100.64.0.160 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.161 to-addresses=192.0.254.2 to-ports=41250-41499
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.161 to-addresses=192.0.254.2 to-ports=41250-41499
add action=src-nat chain=NAT444-10 src-address=100.64.0.161 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.162 to-addresses=192.0.254.2 to-ports=41500-41749
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.162 to-addresses=192.0.254.2 to-ports=41500-41749
add action=src-nat chain=NAT444-10 src-address=100.64.0.162 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.163 to-addresses=192.0.254.2 to-ports=41750-41999
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.163 to-addresses=192.0.254.2 to-ports=41750-41999
add action=src-nat chain=NAT444-10 src-address=100.64.0.163 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.164 to-addresses=192.0.254.2 to-ports=42000-42249
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.164 to-addresses=192.0.254.2 to-ports=42000-42249
add action=src-nat chain=NAT444-10 src-address=100.64.0.164 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.165 to-addresses=192.0.254.2 to-ports=42250-42499
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.165 to-addresses=192.0.254.2 to-ports=42250-42499
add action=src-nat chain=NAT444-10 src-address=100.64.0.165 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.166 to-addresses=192.0.254.2 to-ports=42500-42749
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.166 to-addresses=192.0.254.2 to-ports=42500-42749
add action=src-nat chain=NAT444-10 src-address=100.64.0.166 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.167 to-addresses=192.0.254.2 to-ports=42750-42999
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.167 to-addresses=192.0.254.2 to-ports=42750-42999
add action=src-nat chain=NAT444-10 src-address=100.64.0.167 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.168 to-addresses=192.0.254.2 to-ports=43000-43249
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.168 to-addresses=192.0.254.2 to-ports=43000-43249
add action=src-nat chain=NAT444-10 src-address=100.64.0.168 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.169 to-addresses=192.0.254.2 to-ports=43250-43499
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.169 to-addresses=192.0.254.2 to-ports=43250-43499
add action=src-nat chain=NAT444-10 src-address=100.64.0.169 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.170 to-addresses=192.0.254.2 to-ports=43500-43749
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.170 to-addresses=192.0.254.2 to-ports=43500-43749
add action=src-nat chain=NAT444-10 src-address=100.64.0.170 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.171 to-addresses=192.0.254.2 to-ports=43750-43999
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.171 to-addresses=192.0.254.2 to-ports=43750-43999
add action=src-nat chain=NAT444-10 src-address=100.64.0.171 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.172 to-addresses=192.0.254.2 to-ports=44000-44249
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.172 to-addresses=192.0.254.2 to-ports=44000-44249
add action=src-nat chain=NAT444-10 src-address=100.64.0.172 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.173 to-addresses=192.0.254.2 to-ports=44250-44499
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.173 to-addresses=192.0.254.2 to-ports=44250-44499
add action=src-nat chain=NAT444-10 src-address=100.64.0.173 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.174 to-addresses=192.0.254.2 to-ports=44500-44749
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.174 to-addresses=192.0.254.2 to-ports=44500-44749
add action=src-nat chain=NAT444-10 src-address=100.64.0.174 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-10 protocol=tcp src-address=100.64.0.175 to-addresses=192.0.254.2 to-ports=44750-44999
add action=src-nat chain=NAT444-10 protocol=udp src-address=100.64.0.175 to-addresses=192.0.254.2 to-ports=44750-44999
add action=src-nat chain=NAT444-10 src-address=100.64.0.175 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.176 to-addresses=192.0.254.2 to-ports=45000-45249
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.176 to-addresses=192.0.254.2 to-ports=45000-45249
add action=src-nat chain=NAT444-11 src-address=100.64.0.176 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.177 to-addresses=192.0.254.2 to-ports=45250-45499
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.177 to-addresses=192.0.254.2 to-ports=45250-45499
add action=src-nat chain=NAT444-11 src-address=100.64.0.177 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.178 to-addresses=192.0.254.2 to-ports=45500-45749
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.178 to-addresses=192.0.254.2 to-ports=45500-45749
add action=src-nat chain=NAT444-11 src-address=100.64.0.178 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.179 to-addresses=192.0.254.2 to-ports=45750-45999
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.179 to-addresses=192.0.254.2 to-ports=45750-45999
add action=src-nat chain=NAT444-11 src-address=100.64.0.179 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.180 to-addresses=192.0.254.2 to-ports=46000-46249
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.180 to-addresses=192.0.254.2 to-ports=46000-46249
add action=src-nat chain=NAT444-11 src-address=100.64.0.180 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.181 to-addresses=192.0.254.2 to-ports=46250-46499
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.181 to-addresses=192.0.254.2 to-ports=46250-46499
add action=src-nat chain=NAT444-11 src-address=100.64.0.181 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.182 to-addresses=192.0.254.2 to-ports=46500-46749
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.182 to-addresses=192.0.254.2 to-ports=46500-46749
add action=src-nat chain=NAT444-11 src-address=100.64.0.182 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.183 to-addresses=192.0.254.2 to-ports=46750-46999
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.183 to-addresses=192.0.254.2 to-ports=46750-46999
add action=src-nat chain=NAT444-11 src-address=100.64.0.183 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.184 to-addresses=192.0.254.2 to-ports=47000-47249
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.184 to-addresses=192.0.254.2 to-ports=47000-47249
add action=src-nat chain=NAT444-11 src-address=100.64.0.184 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.185 to-addresses=192.0.254.2 to-ports=47250-47499
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.185 to-addresses=192.0.254.2 to-ports=47250-47499
add action=src-nat chain=NAT444-11 src-address=100.64.0.185 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.186 to-addresses=192.0.254.2 to-ports=47500-47749
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.186 to-addresses=192.0.254.2 to-ports=47500-47749
add action=src-nat chain=NAT444-11 src-address=100.64.0.186 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.187 to-addresses=192.0.254.2 to-ports=47750-47999
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.187 to-addresses=192.0.254.2 to-ports=47750-47999
add action=src-nat chain=NAT444-11 src-address=100.64.0.187 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.188 to-addresses=192.0.254.2 to-ports=48000-48249
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.188 to-addresses=192.0.254.2 to-ports=48000-48249
add action=src-nat chain=NAT444-11 src-address=100.64.0.188 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.189 to-addresses=192.0.254.2 to-ports=48250-48499
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.189 to-addresses=192.0.254.2 to-ports=48250-48499
add action=src-nat chain=NAT444-11 src-address=100.64.0.189 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.190 to-addresses=192.0.254.2 to-ports=48500-48749
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.190 to-addresses=192.0.254.2 to-ports=48500-48749
add action=src-nat chain=NAT444-11 src-address=100.64.0.190 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-11 protocol=tcp src-address=100.64.0.191 to-addresses=192.0.254.2 to-ports=48750-48999
add action=src-nat chain=NAT444-11 protocol=udp src-address=100.64.0.191 to-addresses=192.0.254.2 to-ports=48750-48999
add action=src-nat chain=NAT444-11 src-address=100.64.0.191 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.192 to-addresses=192.0.254.2 to-ports=49000-49249
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.192 to-addresses=192.0.254.2 to-ports=49000-49249
add action=src-nat chain=NAT444-12 src-address=100.64.0.192 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.193 to-addresses=192.0.254.2 to-ports=49250-49499
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.193 to-addresses=192.0.254.2 to-ports=49250-49499
add action=src-nat chain=NAT444-12 src-address=100.64.0.193 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.194 to-addresses=192.0.254.2 to-ports=49500-49749
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.194 to-addresses=192.0.254.2 to-ports=49500-49749
add action=src-nat chain=NAT444-12 src-address=100.64.0.194 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.195 to-addresses=192.0.254.2 to-ports=49750-49999
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.195 to-addresses=192.0.254.2 to-ports=49750-49999
add action=src-nat chain=NAT444-12 src-address=100.64.0.195 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.196 to-addresses=192.0.254.2 to-ports=50000-50249
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.196 to-addresses=192.0.254.2 to-ports=50000-50249
add action=src-nat chain=NAT444-12 src-address=100.64.0.196 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.197 to-addresses=192.0.254.2 to-ports=50250-50499
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.197 to-addresses=192.0.254.2 to-ports=50250-50499
add action=src-nat chain=NAT444-12 src-address=100.64.0.197 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.198 to-addresses=192.0.254.2 to-ports=50500-50749
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.198 to-addresses=192.0.254.2 to-ports=50500-50749
add action=src-nat chain=NAT444-12 src-address=100.64.0.198 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.199 to-addresses=192.0.254.2 to-ports=50750-50999
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.199 to-addresses=192.0.254.2 to-ports=50750-50999
add action=src-nat chain=NAT444-12 src-address=100.64.0.199 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.200 to-addresses=192.0.254.2 to-ports=51000-51249
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.200 to-addresses=192.0.254.2 to-ports=51000-51249
add action=src-nat chain=NAT444-12 src-address=100.64.0.200 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.201 to-addresses=192.0.254.2 to-ports=51250-51499
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.201 to-addresses=192.0.254.2 to-ports=51250-51499
add action=src-nat chain=NAT444-12 src-address=100.64.0.201 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.202 to-addresses=192.0.254.2 to-ports=51500-51749
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.202 to-addresses=192.0.254.2 to-ports=51500-51749
add action=src-nat chain=NAT444-12 src-address=100.64.0.202 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.203 to-addresses=192.0.254.2 to-ports=51750-51999
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.203 to-addresses=192.0.254.2 to-ports=51750-51999
add action=src-nat chain=NAT444-12 src-address=100.64.0.203 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.204 to-addresses=192.0.254.2 to-ports=52000-52249
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.204 to-addresses=192.0.254.2 to-ports=52000-52249
add action=src-nat chain=NAT444-12 src-address=100.64.0.204 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.205 to-addresses=192.0.254.2 to-ports=52250-52499
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.205 to-addresses=192.0.254.2 to-ports=52250-52499
add action=src-nat chain=NAT444-12 src-address=100.64.0.205 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.206 to-addresses=192.0.254.2 to-ports=52500-52749
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.206 to-addresses=192.0.254.2 to-ports=52500-52749
add action=src-nat chain=NAT444-12 src-address=100.64.0.206 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-12 protocol=tcp src-address=100.64.0.207 to-addresses=192.0.254.2 to-ports=52750-52999
add action=src-nat chain=NAT444-12 protocol=udp src-address=100.64.0.207 to-addresses=192.0.254.2 to-ports=52750-52999
add action=src-nat chain=NAT444-12 src-address=100.64.0.207 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.208 to-addresses=192.0.254.2 to-ports=53000-53249
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.208 to-addresses=192.0.254.2 to-ports=53000-53249
add action=src-nat chain=NAT444-13 src-address=100.64.0.208 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.209 to-addresses=192.0.254.2 to-ports=53250-53499
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.209 to-addresses=192.0.254.2 to-ports=53250-53499
add action=src-nat chain=NAT444-13 src-address=100.64.0.209 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.210 to-addresses=192.0.254.2 to-ports=53500-53749
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.210 to-addresses=192.0.254.2 to-ports=53500-53749
add action=src-nat chain=NAT444-13 src-address=100.64.0.210 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.211 to-addresses=192.0.254.2 to-ports=53750-53999
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.211 to-addresses=192.0.254.2 to-ports=53750-53999
add action=src-nat chain=NAT444-13 src-address=100.64.0.211 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.212 to-addresses=192.0.254.2 to-ports=54000-54249
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.212 to-addresses=192.0.254.2 to-ports=54000-54249
add action=src-nat chain=NAT444-13 src-address=100.64.0.212 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.213 to-addresses=192.0.254.2 to-ports=54250-54499
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.213 to-addresses=192.0.254.2 to-ports=54250-54499
add action=src-nat chain=NAT444-13 src-address=100.64.0.213 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.214 to-addresses=192.0.254.2 to-ports=54500-54749
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.214 to-addresses=192.0.254.2 to-ports=54500-54749
add action=src-nat chain=NAT444-13 src-address=100.64.0.214 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.215 to-addresses=192.0.254.2 to-ports=54750-54999
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.215 to-addresses=192.0.254.2 to-ports=54750-54999
add action=src-nat chain=NAT444-13 src-address=100.64.0.215 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.216 to-addresses=192.0.254.2 to-ports=55000-55249
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.216 to-addresses=192.0.254.2 to-ports=55000-55249
add action=src-nat chain=NAT444-13 src-address=100.64.0.216 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.217 to-addresses=192.0.254.2 to-ports=55250-55499
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.217 to-addresses=192.0.254.2 to-ports=55250-55499
add action=src-nat chain=NAT444-13 src-address=100.64.0.217 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.218 to-addresses=192.0.254.2 to-ports=55500-55749
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.218 to-addresses=192.0.254.2 to-ports=55500-55749
add action=src-nat chain=NAT444-13 src-address=100.64.0.218 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.219 to-addresses=192.0.254.2 to-ports=55750-55999
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.219 to-addresses=192.0.254.2 to-ports=55750-55999
add action=src-nat chain=NAT444-13 src-address=100.64.0.219 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.220 to-addresses=192.0.254.2 to-ports=56000-56249
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.220 to-addresses=192.0.254.2 to-ports=56000-56249
add action=src-nat chain=NAT444-13 src-address=100.64.0.220 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.221 to-addresses=192.0.254.2 to-ports=56250-56499
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.221 to-addresses=192.0.254.2 to-ports=56250-56499
add action=src-nat chain=NAT444-13 src-address=100.64.0.221 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.222 to-addresses=192.0.254.2 to-ports=56500-56749
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.222 to-addresses=192.0.254.2 to-ports=56500-56749
add action=src-nat chain=NAT444-13 src-address=100.64.0.222 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-13 protocol=tcp src-address=100.64.0.223 to-addresses=192.0.254.2 to-ports=56750-56999
add action=src-nat chain=NAT444-13 protocol=udp src-address=100.64.0.223 to-addresses=192.0.254.2 to-ports=56750-56999
add action=src-nat chain=NAT444-13 src-address=100.64.0.223 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.224 to-addresses=192.0.254.2 to-ports=57000-57249
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.224 to-addresses=192.0.254.2 to-ports=57000-57249
add action=src-nat chain=NAT444-14 src-address=100.64.0.224 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.225 to-addresses=192.0.254.2 to-ports=57250-57499
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.225 to-addresses=192.0.254.2 to-ports=57250-57499
add action=src-nat chain=NAT444-14 src-address=100.64.0.225 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.226 to-addresses=192.0.254.2 to-ports=57500-57749
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.226 to-addresses=192.0.254.2 to-ports=57500-57749
add action=src-nat chain=NAT444-14 src-address=100.64.0.226 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.227 to-addresses=192.0.254.2 to-ports=57750-57999
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.227 to-addresses=192.0.254.2 to-ports=57750-57999
add action=src-nat chain=NAT444-14 src-address=100.64.0.227 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.228 to-addresses=192.0.254.2 to-ports=58000-58249
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.228 to-addresses=192.0.254.2 to-ports=58000-58249
add action=src-nat chain=NAT444-14 src-address=100.64.0.228 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.229 to-addresses=192.0.254.2 to-ports=58250-58499
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.229 to-addresses=192.0.254.2 to-ports=58250-58499
add action=src-nat chain=NAT444-14 src-address=100.64.0.229 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.230 to-addresses=192.0.254.2 to-ports=58500-58749
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.230 to-addresses=192.0.254.2 to-ports=58500-58749
add action=src-nat chain=NAT444-14 src-address=100.64.0.230 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.231 to-addresses=192.0.254.2 to-ports=58750-58999
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.231 to-addresses=192.0.254.2 to-ports=58750-58999
add action=src-nat chain=NAT444-14 src-address=100.64.0.231 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.232 to-addresses=192.0.254.2 to-ports=59000-59249
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.232 to-addresses=192.0.254.2 to-ports=59000-59249
add action=src-nat chain=NAT444-14 src-address=100.64.0.232 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.233 to-addresses=192.0.254.2 to-ports=59250-59499
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.233 to-addresses=192.0.254.2 to-ports=59250-59499
add action=src-nat chain=NAT444-14 src-address=100.64.0.233 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.234 to-addresses=192.0.254.2 to-ports=59500-59749
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.234 to-addresses=192.0.254.2 to-ports=59500-59749
add action=src-nat chain=NAT444-14 src-address=100.64.0.234 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.235 to-addresses=192.0.254.2 to-ports=59750-59999
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.235 to-addresses=192.0.254.2 to-ports=59750-59999
add action=src-nat chain=NAT444-14 src-address=100.64.0.235 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.236 to-addresses=192.0.254.2 to-ports=60000-60249
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.236 to-addresses=192.0.254.2 to-ports=60000-60249
add action=src-nat chain=NAT444-14 src-address=100.64.0.236 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.237 to-addresses=192.0.254.2 to-ports=60250-60499
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.237 to-addresses=192.0.254.2 to-ports=60250-60499
add action=src-nat chain=NAT444-14 src-address=100.64.0.237 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.238 to-addresses=192.0.254.2 to-ports=60500-60749
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.238 to-addresses=192.0.254.2 to-ports=60500-60749
add action=src-nat chain=NAT444-14 src-address=100.64.0.238 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-14 protocol=tcp src-address=100.64.0.239 to-addresses=192.0.254.2 to-ports=60750-60999
add action=src-nat chain=NAT444-14 protocol=udp src-address=100.64.0.239 to-addresses=192.0.254.2 to-ports=60750-60999
add action=src-nat chain=NAT444-14 src-address=100.64.0.239 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.240 to-addresses=192.0.254.2 to-ports=61000-61249
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.240 to-addresses=192.0.254.2 to-ports=61000-61249
add action=src-nat chain=NAT444-15 src-address=100.64.0.240 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.241 to-addresses=192.0.254.2 to-ports=61250-61499
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.241 to-addresses=192.0.254.2 to-ports=61250-61499
add action=src-nat chain=NAT444-15 src-address=100.64.0.241 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.242 to-addresses=192.0.254.2 to-ports=61500-61749
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.242 to-addresses=192.0.254.2 to-ports=61500-61749
add action=src-nat chain=NAT444-15 src-address=100.64.0.242 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.243 to-addresses=192.0.254.2 to-ports=61750-61999
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.243 to-addresses=192.0.254.2 to-ports=61750-61999
add action=src-nat chain=NAT444-15 src-address=100.64.0.243 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.244 to-addresses=192.0.254.2 to-ports=62000-62249
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.244 to-addresses=192.0.254.2 to-ports=62000-62249
add action=src-nat chain=NAT444-15 src-address=100.64.0.244 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.245 to-addresses=192.0.254.2 to-ports=62250-62499
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.245 to-addresses=192.0.254.2 to-ports=62250-62499
add action=src-nat chain=NAT444-15 src-address=100.64.0.245 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.246 to-addresses=192.0.254.2 to-ports=62500-62749
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.246 to-addresses=192.0.254.2 to-ports=62500-62749
add action=src-nat chain=NAT444-15 src-address=100.64.0.246 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.247 to-addresses=192.0.254.2 to-ports=62750-62999
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.247 to-addresses=192.0.254.2 to-ports=62750-62999
add action=src-nat chain=NAT444-15 src-address=100.64.0.247 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.248 to-addresses=192.0.254.2 to-ports=63000-63249
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.248 to-addresses=192.0.254.2 to-ports=63000-63249
add action=src-nat chain=NAT444-15 src-address=100.64.0.248 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.249 to-addresses=192.0.254.2 to-ports=63250-63499
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.249 to-addresses=192.0.254.2 to-ports=63250-63499
add action=src-nat chain=NAT444-15 src-address=100.64.0.249 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.250 to-addresses=192.0.254.2 to-ports=63500-63749
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.250 to-addresses=192.0.254.2 to-ports=63500-63749
add action=src-nat chain=NAT444-15 src-address=100.64.0.250 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.251 to-addresses=192.0.254.2 to-ports=63750-63999
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.251 to-addresses=192.0.254.2 to-ports=63750-63999
add action=src-nat chain=NAT444-15 src-address=100.64.0.251 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.252 to-addresses=192.0.254.2 to-ports=64000-64249
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.252 to-addresses=192.0.254.2 to-ports=64000-64249
add action=src-nat chain=NAT444-15 src-address=100.64.0.252 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.253 to-addresses=192.0.254.2 to-ports=64250-64499
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.253 to-addresses=192.0.254.2 to-ports=64250-64499
add action=src-nat chain=NAT444-15 src-address=100.64.0.253 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.254 to-addresses=192.0.254.2 to-ports=64500-64749
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.254 to-addresses=192.0.254.2 to-ports=64500-64749
add action=src-nat chain=NAT444-15 src-address=100.64.0.254 to-addresses=192.0.254.2
add action=src-nat chain=NAT444-15 protocol=tcp src-address=100.64.0.255 to-addresses=192.0.254.2 to-ports=64750-64999
add action=src-nat chain=NAT444-15 protocol=udp src-address=100.64.0.255 to-addresses=192.0.254.2 to-ports=64750-64999
add action=src-nat chain=NAT444-15 src-address=100.64.0.255 to-addresses=192.0.254.2
end of this NAT444 configuration
i think no tcp-udp rules can be sumarized in one rule at the end
add action=src-nat chain=src-nat src-address=100.64.0.0/24 to-addresses=192.0.254.2
save 260 lines with that
What I like about my lengthy NAT444 configuration is:
If/when I receive a copyright notice stating somebody is downloading copyrighted stuff
( I get these all of the time where customers are downloaded copyrighted movies )
The copyright notice included the IP address and the port number of the offender ( my customer ).
So , lets say a notice states IP address 192.0.254.2 ( My WAN or a static IP address to my NAT444 router )
and it states the port # used was # 33051
I can scan my NAT444 configuration for the IP address and the port then easily see the inside CGN IP address which in this case would be the customer on CGN IP address 100.64.0.128
With regular NAT44 you can’t do that.
i refer to this kind of rules without port numbers
there is no need of individual rule for every host
This feature will work just fine with netmap if done correctly. It’s documented here already: http://forum.mikrotik.com/t/how-to-edge-router-and-bng-optimization-for-isps/150007/1
Plus with the above method, you can also ensure layer 4 protocols such as SCTP, DCCP, UDP-Lite will work along with P2P networking such as BitTorrent seeding etc.
Folks, this feature request has nothing to do with Fixed port NAT that uses these hundreds of rules. Please don’t mix up the topic. This is about Bulk Port Allocation allocation feature.
Nor it has to do with Netmap feature which is another topic and not the same thing as Bulk Port Allocation.
