Feature request: CLI hints in WinBox
Kinda idea for geeks, anyway: working in Firewall via WinBox I thought it would be nice to see Terminal command for current rule on bottom, like this:
so you don’t need to click all tabs to see some accidentally set values
devs, how real is this? :slight_smile:
Nice! ++
Nice idea, if doable with reasonable effort. :slight_smile:
Not only in previewing purposes, but sounds also quite good way to learn CLI for the beginners..
absolutely nice ++
+1
Yes, it would be nice.
A good one. Time and again I had to create something, just to see the correct syntax.
In the past I have also suggested to add a button to show the export of the current section, to have a quick
and complete overview of everything that is configured in that section (e.g. firewall). This request could be
seen as an addition to that, but at the level of a single entry instead of an entire section.
And that the command should be selectable so you can copy / paste it.
