Having the ability to connect using Winbox from inside Winbox would be very useful, especially if i have multiple Mikrotik devices in my local network.
We already can do SSH or Telnet from inside Winbox, why not doing Winbox too?!
Best Regards…
Best Regards…
I think I asked for it some time ago already. But I don’t expect it will be done.
+1 for Winbox daisy-chaining.
you can use dst-nat
DST-NAT wont work for winbox
then how it is working for me??
dst-nat is just used to port forewad and it will work with proper setup
I think the idea is to connect from one device to the other like mac-telnet, ssh, etc. No setup required, and always nice to have in a panic.
Should be fairly straight forward. “Connect to another device” button. Enter in the IP, and then winbox sends commands to the first RB, which in turn relay’s it to the next one.
Nice for when there are gateway or route issues.
Exactly. This is the idea.
Sure. Almost.
