[Feature request] Copy and paste on web-ui terminal
From at least version 6.44.2 forward (probably even before) it’s impossible to copy using Ctrl+c or pasting scripts using Ctrl+v or any other method , to the web ui terminal.
Allowing copy and paste in the web ui is very usefull and saves a lot of time.
It’s probably a a helpfull feature for a lot of customers
Ctrl + C on every terminal is used for terminate the execution if a command.
You are correct, in terminal I use Ctrl + Shift + C but on web pages Ctrl + C should do the job
