Hi everyone,
I'm investigating whether it is possible to disable the RJ45 Link/Activity LEDs on the CRS310-8G+2S+IN while keeping all Ethernet interfaces operational.
I'm planning to use this switch in a home network, near a television, where the constantly blinking LEDs can be distracting in a dark room.
My preferred operating system is actually SwOS, as I primarily need Layer 2 switching. However, I would love to see this functionality implemented in both SwOS and RouterOS.
Hardware and software:
Device: CRS310-8G+2S+IN
RouterOS tested: 7.20.8 (long-term)
Switch ASIC: Marvell Prestera 98DX226S
Ethernet PHY: reportedly Marvell 88E2180
What I've tested in RouterOS:
The following command:
/system leds settings set all-leds-off=immediate
Returns:
failure: This feature is not supported on this board!
However, /system leds print detail exposes four configurable LEDs associated with the SFP+ interfaces.
Setting type=off successfully disables those SFP+ LEDs, but the RJ45 LEDs are not exposed through /system leds.
Potential hardware-level solution
Based on the Marvell Alaska 88E21x0 documentation, the 88E2180 PHY appears to support programmable LED behavior through MDIO Clause 45 registers, including the MMD 31 LED configuration register range.
This suggests it may be technically possible to disable the RJ45 LEDs without affecting the physical Ethernet connections.
However, I have not confirmed the actual LED wiring on the MikroTik PCB.
Feature request for RouterOS and SwOS
Ideally, I would like to see:
RouterOS: RJ45 LEDs exposed through
/system leds, with support fortype=offand preferably global LED Dark Mode. -
SwOS: a simple
Port LEDs On/Offoption in the web interface, ideally with both global and per-port controls. -
Settings preserved across reboots.
Normal Ethernet link negotiation and traffic unaffected.
Questions for MikroTik and the community:
Can the RJ45 LEDs be controlled independently through the Marvell 88E2180 PHY on this particular board?
Is there an existing mechanism for disabling these LEDs in SwOS or RouterOS?
Would implementing LED control in both operating systems be technically feasible?
Has anyone experimented with the PHY LED registers on this or another MikroTik switch?
Could MikroTik consider adding this as an official feature?
I'm happy to test potential implementations on my own CRS310 and provide diagnostics if needed.
Thanks for any technical insights!
