Please,
would you consider adding the posibility to select packages from offered list of available packages before an update is performed?
It should allow to add additional package that was not installed before, so it could not be updated automatically.
The same option should be available for the actually installed version - to add a package by direct download from the upgrade.mikrotik.com site without any need of manual work - to find a zip file, download, unzip, copy the files to the router and reboot. The functionality is already there, only provide the ability to the user to choose what to add…
Hope you understand.
Thank you for your consideration and thanks in advance for the support to this request to those who find it useful.
edit: This si my post number 5.000! I can not believe it…
