Could you create in the future option called: “block netinstall”. We would like to provide routerboards as own devices and we want to prevent flashing it by client, becouse we’ve got a solutions to load custom config after reset…
Netinstall will be need to provide a pin code to flash…
how do you want to solve your clients with an update or upgrade?
Upgrading RouterOS or RouterBOOT is not the same as using Netinstall.
RouterOS/RouterBOOT upgrade keeps current router configuration unmodified,
Netinstall removes it and writes ‘factory default’.
@HaPe
Netinstall is only way to reset locked RouterBoards and IMHO MikroTik will never
make option to disable it.
If your customers are so clever and they will use Netinstall to reset RB to factory default,
charge some fee for RouterOS reinstallation with your default, because Netinstall can’t be used by them ‘accidentally’.
