Overview
I’d like to request a new RouterOS feature that allows traffic enforcement based on successful DNS resolution.
In essence, the firewall should allow forwarding only to destinations that have been successfully resolved via the router’s DNS cache or internal resolver.
If a domain cannot be resolved (NXDOMAIN, timeout, or blocked entry), the associated traffic should be automatically dropped.
This would give administrators complete DNS-level control over outbound traffic—an important capability for ISPs, enterprise networks, and secure environments where name resolution directly governs allowed destinations.
Proposed Functionality
1. Concept
The router acts as the authoritative DNS resolver for the LAN.
If a hostname resolves successfully, its IP (A/AAAA record) is added to a special dynamic address list (e.g., `resolved-list`).
Firewall rules can then reference this list:
add chain=forward dst-address-list=resolved-list action=accept
add chain=forward action=drop -
If DNS resolution fails or is blocked, the IP never enters the list, so packets are dropped.
2. Optional Mode
set resolve-enforcement=yes
When enabled, RouterOS only allows outbound connections to IPs associated with successful DNS lookups made through the router.
This mode can be per-interface or global.
3. Internal Implementation
RouterOS already maintains a full DNS cache table.
The feature could simply expose the cache-linked IPs to a dynamic address list at kernel level.
Optionally, use a new `/ip firewall match=dns-resolved` condition integrated into nftables/ipset (as RouterOS v7 already runs on Linux kernel 5.x+).
Suggested kernel-level approach:
For every DNS cache entry, push resolved IPs to a kernel-managed nftables set (type `ipv4_addr`/`ipv6_addr`).
TTL synchronization = DNS TTL (automatic removal upon expiry).
Hook existing DNS resolver process to maintain this set.
This avoids user-space scripts and leverages existing nftables mechanisms for high performance.
4. Implementation Options
Option 1: Address-List Synchronization (Simple Implementation)
Mirror `/ip dns cache` entries to a dynamic `resolved-list`.
TTL synchronization ensures entries expire naturally.
Advantage: straightforward to implement using existing address-list logic.
Limitation: large address-lists may increase memory usage and CPU cost on busy gateways.
Option 2: New Firewall Option — `match-dns` (Preferred)
To minimize address-list overhead, add a direct DNS verification flag to the firewall filter:
add chain=forward action=accept match-dns=yes
5. Possible CLI Design
/ip dns control
add name="resolved" list=resolved-list ttl-sync=yes
or a new match condition:
add chain=forward match-dns=yes action=accept
Use Cases
Strict outbound policy – Prevents any host from connecting to IPs that haven’t passed DNS validation.
DNS-driven allowlists/denylists – Allows micro-segmentation and per-domain policy enforcement.
Malware and data exfiltration prevention – Stops direct IP-based connections to C2 servers.
ISP / corporate gateway control – Enforces “if you can’t resolve, you can’t connect,” eliminating leaks via hardcoded IPs.
Why This Matters
Competing platforms (Linux + dnsmasq + nftables) already achieve this natively using `ipset=/#/setname`.
MikroTik could integrate similar logic internally, without external scripts or schedulers.
It would greatly simplify compliance, auditing, and threat-mitigation for MikroTik-based ISP and enterprise deployments.
Summary
Requested Feature:
Add native RouterOS support for DNS-to-firewall synchronization—allowing traffic only to successfully resolved IPs (resolve-or-block mode).
Technical Suggestion:
Expose `/ip dns cache` IPs as a dynamic address list or nftables set; TTL-synchronized and directly usable in `/ip firewall filter`.
Thank you for considering this feature. This enhancement aligns perfectly with MikroTik’s firewall philosophy—lightweight, deterministic, and controllable directly from RouterOS, without needing custom scripts.
