Are we able to get access to the DNSRCH toggle in the mikrotik DNS cache?
We have a domain setup on our local DHCP server and this has caused some issues wherein DNS lookups passing to domains like example.com will recursively lookup example.com..com.au and then example.com.com.au, then caching the NXDOMAIN response for the TTL time set on the mikrotik. I understand that the value on the mikrotik can be changed but simply setting it to 1minute or similar removes the whole point of having a local caching DNS server.
http://hissohathair.blogspot.com/2009/04/welcome-to-aszcomau-or-resolver-library.html - this is an old blogpost I discovered that explains a little bit more about the issues that are similar to what I am seeing.
http://www.manpagez.com/man/3/resolver/
RES_DNSRCH If this option is set, res_search() will search for host
names in the current domain and in parent domains; see
hostname(7). This is used by the standard host lookup
routine gethostbyname(3). This option is enabled by
default.
